Just Bought 1995 GS. Questions/Concerns.
    Hey Guys!
    I'm having some problems with Janet. She's a 95 GS. Got her almost two weeks ago for $1300 with 69,200 miles on her. Red exterior with clearcoat peeling and tan interior. Here's my questions/concerns:
    How do I know if she's a "base" car or if she has some options? I've looked online, no real help.
    I don't have the original hubcap key and it's hard to replace tires/hubcaps. (Got some newer fronts, very hard time). Can this be replaced?
    My check engine light is on and I need to pass the Ohio E-Check before I can get plates and registration. Supposedly it's my EGR Valve says the AutoZone guy and his OBD meter. Is this hard to change own my own? He claims it wouldn't be.
    How can I tell if my car has the air ride suspension? The front does seem to be a little lower than the rear of the car, like someone may have replace something.
    Anyone know about idler arms? I need a right one I've been told, as my steering wheel is off and they can't do the wheel alignment until that gets done.
    Any common problems or anything I should look out for?
    I've attached a pic of her.
    I'm a college student so I hope she won't take too much of my money. From what I read, these cars are really good and pretty cheap to own.
    Thanks!!!
    Howdy GMGS!
    You can pass an echeck now if your check engine light is on, they stick it on the dyno like the good old days and as long as the exhaust is clean enough it still passes.
    Here's how to clean the EGR: http://www.lincolnsonline.com/tech/00015.html
    Idler is easy. You can get a super cheap one online but it might die quick. I think this one looks interesting: http://www.ebay.com/itm/NORS-78-80-8...5523cd&vxp=mtr
    Check out the pic then crawl under your car on the passenger side and look for it. It'll be bolted to the frame. It's a very straighforward job. Often though it means the pitman arm isn't far behind.
    If your car has air suspension then it won't have metal rear springs, there will be rubber bladders instead.
    Your hubcaps have that screw that holds them on? Once you get them out head down to the hardware store and buy regular bolts the same thread/length, problem solved
    Gotta run. others will chime in. Congrats, and good luck.
    Pete
      Put a touch of antiseize on the bolts before you install them.
        Where abouts in Ohio are you?
        I got a idler arm from RockAuto.com for $11. Easy.
        EGR cleaning is gonna be a little bit more difficult. Especially because of the care needed to not break the tube coming from the exhaust manifold.
        Air ride: look for the rubber bags in the back, check for a "ON/OFF" switch on the left side in the trunk, check for a compressor under the air box.
        And I don't deal with hubcaps, so I have no useful info there.
        08 Lincoln Navigator L - 233k
        03 Mercury Marauder- 63k
          Originally posted by Piece-it pete View Post
          Howdy GMGS!
          Pete
          Thank you!!!! That was very helpful!!!!
          Thanks, will do!
          I live in Cleveland. And thanks for the info!! I'm gonna try to look at some stuff tomorrow after work if possible. You guys are already a great help!!!
