anyone know if its possible to put 3v or 4v heads on a 2v motor? i dont really wanna do a motor swap seein as i dont have the time or money
3 valve or 4 valve heads
54,xxx miles. New daily driver
2001 Lincoln Town Car Signature "Leroy"
rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
114k miles. Sold to my coworker.
1998 Toyota Camry "Traveller"
Dead and sold.Tags: None
Yes. 4 valve would be a better choice.
03 Mercury Marauder- 63k
yes. it's basically a top-end replacement though, as far as I know. Intake, ECU, etc.
timing chain cover, timing chain tensioners, injectors, blah. ECU? tune.
thanks yall! ill probably go with 4 valve...whenever i get the money, hahaha2010 Toyota Camry "Traveller II "
Dead and sold.
you dont have time for this either........motor swap would take less time..........is also going to require special tuning that will cost you at lest 600 bucks
thanks Scott, i think i'll just throw a carb on it, hahaha. ill probably end up doin a motor swap in the future, something big and carbureted with room for a supercharger...built 351 maybe, or a 427 if i can find one2010 Toyota Camry "Traveller II "
Dead and sold.
twinscrew on a 351... preferably a cleveland.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
twinscrew is the way to go! though ive heard that the windsors are better for building up than the clevelands, is that true?2010 Toyota Camry "Traveller II "
Dead and sold.
the oiling is better on a windsor, thought the clevland has a better bottom end... which is why you see clevor builds with windsor top half and cleveland bottom half.
This is over a year old, but this forum is quiet.
Originally posted by sly View Postthe oiling is better on a windsor, thought the clevland has a better bottom end... which is why you see clevor builds with windsor top half and cleveland bottom half.
I had that backwards... 351 Cleveland heads to a 351 Windsor block
