87' TC with electronic keyminder dash. When you press the buttons it gives you an audible beep. That sound is no longer working. The entire keyminder functions as it should, just no sound. Anyone know what's going on here? I checked the fuse descriptions in the manual, but don't see anything related. Did something get damaged? Did I unknowingly turn it off somehow?
Electronic Dash No Sound. 87' TC.
87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,Tags: None
It could be because the chime box is bad. The key chime stopped working on mine and I just replaced the box with one from a junkyard. The key chime module also provides the tones for the digital dash/keyminder. It's right under the dash panel to the right of the steering column.
Hmmm. The door chime still works though.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
The shop manual I have says that the door chime and digital dash chime come from the same module, although the tones are different. So it may be possible that one is bad and the one for the doors is good. The chime boxes from a junkyard are cheap anyways, but if you want I can scan the diagnostics page from my shop manual if you're interested in seeing them.
Hey, if you can scan that diag for me I will definitely use it. Where is the keyminder chime located and how do you remove/replace it?87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
ON my 87 vic it is right below the radio. One 7/32 bolt holds its bracket to the frame of the dash. Best accessed from the drivers side foot well right next to the ash tray. Again this if for a crown victoria/grand marquis.~David~
Originally posted by 87gtVIC View PostON my 87 vic it is right below the radio. One 7/32 bolt holds its bracket to the frame of the dash. Best accessed from the drivers side foot well right next to the ash tray. Again this if for a crown victoria/grand marquis.
Nice I'll inspect it. Thank you.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Wonder if anyone has them available besides a JY??
