Town Cars with Aftermarket CD Player bouncing around in dash pocket
    87 Town Car with Aftermarket Kenwood. I have a din kit installed but it doesnt support the rear of the deck. I.t ba1ly suspends it in the din slot and it bounces around when taking bumps. Anybody else experiencing this? I guess I midht have to try a better dash kit
    87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
    Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,
    Probably adding a support strap to the back of the radio and tying it up into the dash somewhere would fix the problem. Not much support out of a plastic ring that holds the DIN mount.
      I modified the stock mount to work with my aftermarket radio. I also made my own mounting plate out of some thick aluminum.
        I remember doing the same as 87gtvic. You can also shove some styrofoam or equivalent under the radio to help as well. Love your TC by the way. Exact color combo of my much missed 89.
        Past Panthers
          Is an 87 Towncar setup different than 89 MGM?
          I also did like 87gtVIC said, I used the stock mounts on my 89 MGM. The mount on the back screwed right on to the stud on the back of my radio just like it was on the stock radio.
          Vic
            There is less room behind a TC radio, than a MGM otherwise identical mounts.
            Past Panthers
              Allright guys. Wanted to see if it was just mine. I'll prop it up witg something. Thanks
                I used the brace off the stock radio on my cars. The aftermarket radios are actually shorter than the stock ones, so it works well (except the vic... that one required some rigging).
