I dropped the transmission pan earlier today and installed a new filter and topped it all off with new fluid. After driving around for ten minutes and checking the fluid again I realized that I forgot one of the seals for the filter in the box. The transmission seems fine but now I'm going to have to redo all my work tomorrow. I also don't want to throw away the $50 worth of brand new transmission fluid I had just bought, so is there a way I can save the fluid where it won't get contaminated after I drain it again?
Boneheaded question
Boneheaded question
2018 Toyota Tacoma TRD Sport | 97k milesTags: None
*bump*
I think I have it all figured out now. I'll just go and buy a new drain pan (preferably one with the storage tank underneath) and drain it there and use it to fill the trans back up. Some people said to filter out the fluid before pouring it back in, but I don't think that will be necessary since the fluid is so new. I'm glad I noticed this before any real damage could have been done!
Agreed, clean drain pan! If the seal's a little squarish thing I'm amazed the tranny shifts right.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
even a new drain pan may have plastic shavings on it... using a shop towel as a filter will work fine, though it will make pouring slow.
make absolutely sure the pan is clean. A towel or a funnel with a fine screen in it will not be a bad idea as a backup filter.86 Lincoln Town Car (Galactica).
Finally finished putting everything back together and added the fluid back in. I used a shop towel as a filter as per slymer's suggestion, but even then there wasn't any debris or dirt in the pan. It was still good to make absolutely sure though.
