Exhaust question...
    Exhaust question...
    Plan on removing my cats and installing a H-pipe and either flowmaster original 40 series or magnaflows and I know the check engine light will come on. I have been planning on doing my exhaust up a little bit because Ive always enjoyed louder vehicles. But with my cats rattling so much, I figured that now is the perfect time to get my exhaust done. I just wanted to know if there is a bypass method that I can do that would remove the check engine light that Im sure I will get from removing the cats. On my last mustang gt I removed the cats and went flowmaster and I removed the check engine light by installing MIL eliminators. Is it possible to install the same MIL eliminators on my 2004 mercury grand marquis 4.6? Thanks
    Not that I'm aware of. Would probably have to tune them out of the ECM. Why not just stick new cats under it and then change the rest of the exhaust from there back? Would probably sound way better in the end. Also, I don't know about the inspections where you live but it would flunk the visual for sure. Just a thought.
    I'd go with Magnaflow for the mufflers. Search youtube for vics with different exhaust setups. There are a ton out there to give you ideas.
      Stick with stainless
