so my hood latch cable snapped earlier and the handle fell out on the floorboard. anyone know how the hell i can get the hood open so i can replace it (or at least put some hood pins in )?
broken hood latch cable
2010 Toyota Camry "Traveller II "
54,xxx miles. New daily driver
2001 Lincoln Town Car Signature "Leroy"
rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
114k miles. Sold to my coworker.
1998 Toyota Camry "Traveller"
Dead and sold.Tags: None
How far in did it break? Maybe you can pull the kick panel and get enough of the cable to grab wit a pair of pliers or vice grips? If that doesn't get it, pull down the driver's front fender liner and locate the cable on the inside of the fender.
2000 Mercury Grand Marquis GS HPP - SOLD
Wore out the cam chain tensioners and jumped time at 176k miles.
The one on my townie is dangling there too. But on my vic the cable melted and I cut it shorter so it hangs under the grill. Then I tied a keyring on the inner cable. Basically you just have to pull the inner cable. If you can't get to it behind kick panel. I'd cut it up and under the hood behind grill. Then strip the cover off so you can pull it.1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
vice grips on the cable if just the plastic handle came off. If it snapped under the hood, you'll have to find your way up from the airdam to pop it.
you can try. You may still need vice grips to grab whatever cable is left and yank on it.
Got any decent curry?
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
too much spam in that curry.
thanks for the replys yall. I ended up crawling underneath the front and reaching up with a pair of needle noses and got it open, but the hood latch itself had broken as well, so I cut it off and put hood pins in cuz I couldn't find any TCs in the junk yard to pull a hood latch off of.2010 Toyota Camry "Traveller II "
Dead and sold.
Originally posted by 01Townie View Postthanks for the replys yall. I ended up crawling underneath the front and reaching up with a pair of needle noses and got it open, but the hood latch itself had broken as well, so I cut it off and put hood pins in cuz I couldn't find any TCs in the junk yard to pull a hood latch off of.
