Pictures
    Pictures
    Can anyone post some of pictures of the following ,which would help greatly.
    On an '86 5.0............one EGR Spacer Gasket, and one Throttle Body Gasket.
    It seems parts people think they are one and the same:-(
    I think they're both the same in most cases... there is this version:
    http://www.grandmarq.net/vb/showthre...l=1#post695772
    (scroll down a little on that post to see the EGR spacer)
    That corner shot should be what you're dealing with on the throttle body side and the standard gaskets are side shots like the intake side. If you have HO parts, the crosshair looking gaskets are what you need on both sides... if you have a lopo, then the corner gasket is what you need on one side.
