Can I use these?
    Can I use these?
    Can I put these wheels and tires on my bone stock 2007 LS without having to order a flash tuner to correct the speedometer?
    They are from a 2013 Mustang.
    Complete set of 2013 Ford Mustang GT OEM wheels, silver bullitts with all season Pirelli P Zero Nero Tires,
    235/50/18. This set only has 8000 miles on them and in excellent condition. Also has the Tire Pressure Sensors installed. I hope this helps.
    Thanks
    Charlie
      The diameter is only 0.2" different. 742 revs per mile stock, 740 revs per mile new wheels. They are close enough that the speedometer readings will basically be exactly the same, and you will not need a retune. Hope that helps!
      1985 2 door LTD 127k miles, Dodge Charger 18" police wheels.
      2003 P71, 100k, 5.4L engine, eaton m112, other stuff.
      Sold: 2003 P71, 2002 P71, 1996 Town Car
        as long as the lug spacing is the same (and I think it is) I know the backspacing looks right on 03+, so yes.
          Yep. That's all identical for 03+ panthers and 05+ mustangs.
            It changes that much from new tires to worn tires. No problem at all.
              Thanks Guys. I will show you how they look after I install them.
