Radio noise question
    I was checking some spare radios out tonight in my Lincoln TC. Two of the Factory am/fm/cass. radios had poping sounds every time a channel was changed. The stations came in however not real clear. Is this a ground problem, amp problem or a bad radio ? A couple of other radios worked just fine
    Radio channel pop is a tuner problem. If it pops during turn-on/off then it's also an amp problem.
