So the nissan is gone. Happy not to be getting 200 to a tank but sad to see it go since its been reliable for the 53k its been in the family. In its place is this 93 Sunbird LE Coupe i picked up for $300. The car is spotless. No rust, No rot, NOTHING AT ALL! It was brought up from alabama 3 years ago the guy i got it from said the person he brought it from moved up and it was then sold to him. Just changed the fuel filter which was almost fully plugged, really dirty air filter, and put a thermostat in it. Tires were shot and a local guy up my street had some like new snows he was selling so i grabbed them. It only has the 2.0L in it and it seems fairly zippy for a small motor. Has to get undercoated ASAP to go through this winter. It has power windows and locks but not power mirrors or cruise unless i havent found that yet.
93 Sunbird LE Coupe
My buddy has a '92 like that with a 5-speed. Went pretty good. Prolly the best J-body car to date. Both reliability and looks.
Sunbird=Funbird.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Went on the road today. Stalled out twice when it was warming up. Need to fix the lock actuators asap or keep doing it by hand. Has no rear window defroster which sucks for up here. Runs alot better since the gas filter was changed. Did the rear shocks today and changed to the snow tires. It is zippy for a little car and just needs little things fixed to be great.2018 F150 XLT 43k
1970 Buick GS 455 Stage 1 44k
1968 Buick Riviera
Well..... After around 800 miles the motor went. Only had 93k on it. Started knocking yesterday when i was heading out and made it little more than a half mile from my house and died. Was a little low on coolant but still had a little more than half the radiator full. Changed the plugs to the new ones i was given with the car. Drivers side 2 were covered in coolant and the passenger 2 were in oil and sludge. I changed the oil at 20 miles after i got it so there was fresh clean oil in it. I had been using lucas injector cleaner and got better mileage. Dont know what happened. Think the head gasket went or the head cracked. Will crank but wont fire. Had it towed home. Camaro is now my daily for a while. Gonna sell the sunbird off now i think. Only have $200 into it other then the few bits it needed. Guessing if it doesnt sell ill fix it during the summer when i have a little more cash flow.2018 F150 XLT 43k
1968 Buick Riviera
I am not familiar with that particular engine but it could be the intake itself.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
The body is so clean on the car it would suck to see it in the junk yard. The motor if it just needs the head done is worth fixing but if the block is cracked or something else i dont know. The camaro sucks in the snow so im hoping this car is a fast fix.2018 F150 XLT 43k
1968 Buick Riviera
I have seen cracked intakes just pour coolant into some of the cylinders.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
So i went out and got it started tonight. Poured antifreeze into the exhaust, leaked it along the 2 driverside plug holes, and needed to have the gas held on some what to stay running. It did idle for 10 seconds and died out again. Thought it was the head gasket. Mechanic friend said after seeing that head is cracked. $350 through work for a ready to install one. Guess im ordering a head this spring.2018 F150 XLT 43k
1968 Buick Riviera
