It appears that winter has finally killed the battery in the Vic. I want to keep it Motorcraft since everything else is factory. The existing battery is only 650CCA. Is there another Motorcraft battery that is larger in CCA that will fit in the stock location?
Motorcraft Battery for my 03 Sport
Thank you. That is exactly what I was looking for. I figured there was a larger one available somewhere.These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
