Engine swap options?
    Hello everyone!
    Unfortunately my 92' Grand Marquis(Boatmobile) is having some heart problems and is currently "dead" for the moment. I beleive its a blown head gasket. My engine created a rather large cloud of white smoke and leaked coolant all over the Southern State Parkway off ramp. In the shop i watched it spew coolant from the exhaust pipes and coolant tank( dont know if thats the proper name). I was wondering would it be better to swap the engine out for another or replace the head gasket and whatever else could be wrong with it? If i were to replace the engine what are my options? cost is an issue but i was thinking an 5.0 or perhaps a 5.4 or 5.8 motor. Any help/suggestions would be appreciated!
    you could do any number of things... the easiest would be just replace the gaskets and flush the coolant and oil and replace with new fluid. Best may be a rebuilt long block. If you have an early 92 (built before 3/92) and have the PRN-OD-D-1, you'll be hard pressed to find someone with a readily available long block and may require rebuilding the one you have as it would be the "bastard block" that uses the older mechanical AOD as opposed to the electronic AODE. You can also just replace the whole engine with a PI engine and intake and keep all the current electrics and it'll probably run even better (may use more gas this way). The least expensive would be the first option and hope the rod bearings haven't been damaged by the coolant in the oil.
      First, I would be examining the condition of the car. Sometime, depending on the condition, you can set your self up in something better, for the cost of the repair. Maybe get your self a highly addictive box
        When i get home from work ill have to check the build date and gear selection and gather more advice. Is replacing the gaskets and fluids something i can do myself in a weekend? and how could i tell if the rod bearings are damaged? I have a haynes manual, im looking for a ford service manual and a few friends willing to work for beer lol..im a noob when it comes to these things and it appears that its in otherwise decent condition. i can make some time to take more pics if needed..i would loveeeeeeeeeeeeeeeeeee an box town car or even a mark continental though
          I second this!
            I concur on the Box motion
              I have never done 4.6 heads but with any head job you need to be prepared for problems, broken bolts being one of them. I would suggest having the heads inspected by a shop before bolting them back down.
                A 302 can be done. Its much more practical if its a bastard block. You're essentially boned on any other modular engines if you have one of those. Me being me, I'd far sooner put a 302 in one of these than any later modular engine. Having been extensively involved with both a 302 conversion and a late 4.6 conversion on a 1992 and 1993 respectively, I can tell you that the 302 was easier to do. I'll also wager it cost a lot less, though I didn't foot the bill for either of those swaps.
                The absolute easiest and least expensive route is to put a stock motor back in it and go.
                  you need to remove all the front accessories and pull the timing cover off to get the heads off to get the gaskets replaced. It can be done in a weekend, but you will also need to realign the timing chain and you may need to replace the tensioners in the process as well as possibly the chain and gears if they are worn as well and it can turn into a much longer job real fast.
                    I'm going to attempt to fix the issue my self or find someone I know with auto knowledge willing to help and see how it goes, I figure since it's already broken there's only room to improve lol. Plan B is new engine, seems like 302s and even 351s a cost less then a 4.6 nearest me, unless I'm looking in the wrong places..One price I found is 2500+ including motor and labor, needed parts etc Another Is 500+ engine price but of unknown quality that a good number?
                      the place to look for engines is car-part.com, it will search all the junkyards in your state for spare engines and some are listed with mileage or whether or not the car came into the junk yard under its own power, etc. All the junk yards use the car-part.com search widget on their websites with a block on all other yards' inventory.
                        Okay, I will check out that site at work later. What cars should I put in the search field to find a 302? What's the difference between HO and regular? How much should I expect to spend on engine and labor? I don't want to get ripped off, I imagine I sound like a easy target at the mechanics shop lol
                          Hi.
                          I'd check your dip stick first to see if it looks like chocolate milk.
                          If it does, that you probably have a bad head gasket. I would like to say that it could be the oil filter adapter gasket, but since you're losing coolant out the exhaust, then it cannot be.
                          These early NPI motors have had issues with INTAKE MANIFOLD GASKETS. I've blown two sets, on the driver's side. That is spread out over 100k, though.
                          Which tailpipe is the coolant coming out of? Just curious.
                          Intake manifold gaskets are not hard to do, they're just time consuming. It can be done by a backyard mechanic, HOWEVER, you will need a fuel rail disconnect kit. It cost me like $10 at Advance.
                          Also, how much coolant is it drinking? If it isn't running hot, then you probably aren't losing a lot.
                          You can us this:
                          http://www.grandmarq.net/vb/showthre...-Manifold-Swap
                          as a guide. Just follow up to Step 15, replace gaskets, then do it in the reverse order. You do NOT need to do Step 8.
                          Oh, and the intake manifold gasket kit is like $30 at Advance, or $20 on RockAuto.com.
                          If you have any other questions, please ask.
                          08 Lincoln Navigator L - 233k
                          03 Mercury Marauder- 63k
                            I'll check the oil tonight when I get home for color. I only have 1 tail pipe and the coolant was shooting out if it and also out of the tank..The total tank leaked out in almost 4, 5 mins from the engine and tailpipe. Car isn't starting but the engine does sound like it's attempting to start(Cranking is the term?)
                              Im not 100% sure, but I believe the plenum gasket was changed before it was discovered that it was a head gasket blown if that helps..is a plenum gasket the same as an intake manifold gasket?
