84 X 1/9 Bertone
There is an engine in there? lol. A newer power train would be cool.
Half a motor anyway. Notice the thick green wire foud it goes to the Lamba sensor it s a shielded wire and was all chewed up were it goes through the wire loom on the overflow tank hose. So the outer wire (ground to the ECM) was shorting TO THE SENSOR + inner wire. Just repaired that today but have to wounder if it dammaged the ECM.Scars are tatoos of the fearless
Interesting. Sure was some interesting electrical systems out there, back in the day.
I'd probably replace the whole run with RG6 (cable TV coax) since I have more than a couple of lengths lying around. and then wrap it in some corrugated loom and tie it down. But then I'm redneck that way.
I'd probably replace the whole run with RG6 (cable TV coax) since I have more than a couple of lengths lying around. and then wrap it in some corrugated loom and tie it down. But then I'm redneck that way.Scars are tatoos of the fearless
I'd probably replace the whole run with RG6 (cable TV coax) since I have more than a couple of lengths lying around. and then wrap it in some corrugated loom and tie it down. But then I'm redneck that way.Vic
Originally posted by turbo2256b View PostThat would be fun. Tearing appart the wiring harness up into the fire wall into the spare tire well behind the passenger seat remove wires from the ECM attach factory connections and reinstall in ECM plugin. The oxy sensor end attach old plug so it matches plug on the Oxy sensor.
The dash actually looks good in that car but, that shifter... I keep wanting to ask, what beer is on tap?
