15" X 10" Wheels
    15" X 10" Wheels
    what backspace do i need? I know mrltd posted a link to a guy on corral who had them on his. i might be ordering wheels and tires for the back soon.
    5.25"-5.5"
    He posted 5", but with 5" and a bubbled Mickey T slick, you will have to at least roll in the inside lip of the fender.
      i plan on rolling the lips anyway, and im going with 325/50 R15 BFG drag radials. thats nearly 26" of rubber in the back :evil:
        26"? So, stock is 27" tall
        I'm looking at 315 or 335 35/17's. in V700's or MX's. Gotta get some 10.5" wide bullitts for those though. Might just get 285/40's for the current 9.5" ones. Need to find out if the 10.5" mustang wheels fit. I'd like to run those all the way around.
        I want to go around corners FAST!
          You can't run more than 4.25" backspacing.
          I fit Mustang wheels (5.72" BS) to my CV and they didn't touch the upper control arms- they were stuck on them. I had to use 1.5" spacers and still barely had room to clear. I'd say run the 10s on the back, but go with 8s on the front.You can fit 5.5" BS in the rear, but the upper control arms bring teh suck up front.
            im going 15X 10 in the rear and 16 X 8 upfront.
              You don't think that'll look kinda funky?
              I'd recommend a 5" backspacing for the rears- it'll give you a solid direct-center WMS (wheel mounting surface), resulting in the best potential weight distribution across the contact patch.
                id go with 17's upfront if tires were cheaper.
                apparently the only black steel wheels i like (The Crager Soft 8 Series 397) dont come in a 15x10 with 5 on 4.25 and 5" of backspace. only 4" of backspace. And the only 16x8 has 5.25 of backspace. i can get a 16 X7 with 4 in of back space, but doing that id be better off just buying 2 98+ steelies. I can get 15s that fit in 8" but the performance tire selection for a 15" rim sucks.
                my only other choice is to wait and see if my friend can get a set of the series 397s custom made. but that probalby wont be cheap.
                  5x4.25? What are you putting them on?
                    if i say 4.25 i mean 4.5 im slightly dyslexic sometimes.
                      alright i can get adapters to run 5 on 5 wheels up front, and then i can run 5 on 4.5 on the rear. the 2 adapters are $40 each and the wheels are $50 and rear wheels are $40 each so a total of $260 to run the wheels i want in the size i want.
                      this will give me 4" backspace front and rear, I would prefer 5" in the rear but i can't get the wheels for that. Running less backspace will put more stress on the bearings, but will also put more weight to the tires.
                        altight just ordered 2 15 x 10 Crager series 397s for the ford bolt pattern 4' back space for $80 and i also ordered 2 325/50R15 BFG drag radials $334 so they should be here the middle of next week. for now i think im just going to get some decent tires up front. and the upgrade at a latter date.
                          Sounds like you've got it figured out.
                          Aren't those Cragar's truck wheels? Get some pictures- I'm curious to see how they look!
                              Those look just like American Racing rock crawler wheels.
                              Do they hold up okay? I like 'em... especially at that price!
                              I wonder how they'd look on my wagon...
