1981 ford ltd. 302v8, aod trans with rod
just replaced the intake gaskets and put on a remanned 2150 motorcraft carb.
manually shifting through the gears, the car is fine.
putting the car in od or d and driving,the car is fine,
when you have the car in od or d and give it gas to pass, the trans doesnt't downshift and the rpms go up. if you let off the gas and drive it's fine.
tv pressure is set per chilton manual and i never had a problem before until now
any thoughts?
any thoughts?
