So I put an 86 valve body and baumann shift kit in my vehicle. Meticulously followed directions every step of the way, triple checking myself with the shift kit install.
Problem is now that it's in, it acts like there is no TV pressure, or a lack of pressure in general. Give it more than a hair of light throttle and it will slip going into every gear. The more you push the more it slips. I tried adjusting the TV pressure multiple times, both on the large adjustment end and the smaller (I have a TV Rod). It strangely seemed to make little difference at all.
Fluid level is good, checked it multiple times once it was hot.
I have one theory, but idk if it is even possible: The linkage is not connecting with the TV valve in the transmission. I did not think it could go together without it being properly connecting that though..
Anyone encountered this??
