Auto Lamp?
    Auto Lamp?
    I just realized that my parts car has the auto lamp feature, has anyone ever retrofitted an auto lamp system into a car that didnt have one? How hard do you think it would be?
    It might not be too hard - you will at least need the light sensor 'eye' under the dash and the headlight switch, most likely also some kind of relay or module Id imagine would be in there.
    If you're lucky the portion for the eye is an add-on for the wiring harness like a tripminder is, and will have its own harnes. Im not sure about that though.
    Id start digging into it and see if you can tell if its tied directly into the harness or not. If you have to use the whole harness (including the portion from the switch to the headlights) it may be very tricky, but still possible
      And if you find out before I do, please advise. I want to add this probably never to be used function to my car as well.
        Alright, Today after I finished my shocks and springs I looked at the auto lamp on the Vic. I pulled the light sensor and the switch. There is a harness connecting the sensor, but wheter or not I have it on my car is a different story. I'll have to pull my dash cover to find out if its a direct plug and go. I sure hope it is. I'll get pics tuesday since i have school and an awards banquet to go to tomarrow.
        I think I might make this a write up/walk through, thats if it works tho.
          i love my autolamps.........i never touch the headlight switch
