Does Your '92 CV/GM or '90-92 TC Need A Wiper Arm?
    I will start off saying I know we have a master parts list in PDF form, but I found an issue for anyone with a 1992 Crown Victoria/Grand Marquis or 1990-1992 Town Car (some early build 1993s may also have the same dilemma). The part number for the Crown Victoria and Grand Marquis rarely, if at all, returns a anymore.
    These years use the pin arms vs. the more typical j-hook setup. Now these years can have their arms swapped to use the j-hooks found on '93-'02s, however, if you decide that you want to have this type (like myself, long story) or need a replacement and feel comfortable not swapping up and continuing to use the pin arms, these are your part numbers:
    F2VY-17527-A - Driver
    F2VY-17526-A - Passenger
    Why list this? Searching for a 1992 wiper arm for a Crown Victoria or Grand Marquis will return arms for the 1979-1991 models! Dorman turns up the most listings for these cars claiming they will work. Obviously they won't as the setup changed between body styles. To circumvent that, look for 1990-1993 Town Cars (where the part number came from). They used the same arm as the Crown Victoria and Grand Marquis for those years, so you can get the aftermarket or NOS pin arms if you so desire. It would seem it might be harder to find the passenger arm than the driver arm in this case, but you still usually can.
    I had to do some research to find a driver side arm replacement for my car using this style arm, and decided I should pass on this info since it might be a little obscure and I certainly don't want anyone ordering the wrong part because it claimed to be usable on your car.
    My Cars:
    Good info. I was looking for a new drivers side one for my '92 a couple years ago, and I too ran into the problem where a search only pulls up an arm for a box.
      I hate those pins. The Grand Marquis got the j hook arms a little while after I got it after the wipers kept falling off. I've seen up to 02 grand marquis that still use those pins.
        My '87 GM has the pins and the '95 has the "J" hook. No issues with either one losing blades.
          That's why I said those looking have the option to switch up to the j-hooks. I've never had a blade fall off, though. I know some people will scream bloody murder about the pins.
          I've got them figured out pretty good these days since I've been using them on my car. I swapped to them after many failed attempts to solve a skip issue on the driver's side using j-hooks, and finally found these to have worked the best, it's just that a 23 year old used part does go the way of other things and wears out, so I needed a replacement and it was a bear to find the right one.
          My Cars:
            Got the same "skip" issue on the driver's side with J hooks on my '95!
              You might want to bend the arm a tad towards the windshield until it feels like there's sufficient pressure holding the blade against the windshield. I did that until the arm couldn't be adjusted without hitting the hood's cowl, so I got a used replacement. Now it's just time for a new one.
              My Cars:
                Some of it has to do with cheap blades. I've had J hook blades come loose when it was some cheap POS with a lousy latch. Same with pins. The two Chevies here use pins, the Lincolns are J hook. I have no particular preference.
                  That's what I did - just a tad at a time but I think it needs a tad more.
