Transmission oil leak
    I just check my trany pan gasket and no leak I notice I had a wet spot under the transmission range sensor what do I need to do
    where is this transmission range sensor
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
      On the driver side on the outside of the trany
        for what car?
          All panthers (if not all RWD Fords). It's the part with both a cable connected to it and a wire harness.
            was going to say dipstick tube seal, but that's passenger side
              Yep idk where to start
                All panthers
                Only the newfangled ones.
                I believe there is a shift shaft seal where the MLPS (manual lever position sensor) lives. if thats bad, it'll leak. I believe you need to take stuff apart to get that out. The shift lever itself probably needs to come out, which requires dropping the pan. If its only a small leak, honestly I'd leave it alone.
                  ... If its only a small leak, honestly I'd leave it alone.
                  I'd use this as an excuse to do a J-MOD sooner rather than later.
                    Ima check it out Thursday morning thanks guy
                      Neutral Safety Switch on the older ones is in the same location.
                        It sucks to pull the seal for that.
                        Best quick fix would be to throw some RTV on it.
                        08 Lincoln Navigator L - 233k
                        03 Mercury Marauder- 63k
                          Great idea, hate dealing with tranny pans!
                            its leaking from the shift shaft seal. you have to remove the shift linkage and trans range sensor from the outside. Then remove the transmission pan, and shifter shaft, replace the seal and put it all back together.
                              what would be a good RTV that trans fluid won't eat through? My tail shaft seal needs some attn on the 93 and I think it's due to someone that worked on it scratching the damn thing.
