First Oil Change on 4.6
    Im doig a first oil change on the 97 Townie, I noticed that the oil filter is not like the 5.0's. It's horizontally bolted to the block. What the frick?!?! Am I wrong? I mean that is the only filter I see. This is going to suck
    Also, someone told me that these 4.6's need 6 quarts of oil, this true?
    I was going to go with 5 W 20 with a car that has 60K on it for winter (Penzoil YB conventional for now) Might change to synthetic later
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
    The filter is horizontal on driverside and I think its five quarts of oil. An on my 96 townie I only use synthetic oil . High mileage at that.
      IIRC it should be 5 qts. and probably a FL-820S (Motorcraft). If it sits like the GM's you may have to turn the steering wheel to your left so the filter clears the steering parts before you remove it.
        http://youtu.be/mGvgRkXu70g?t=1m37s
          yeah have fun with the oil running all over. That wasn't one of their better ideas IMO. They should have remote mounted that thing so it stood vertical, or at least in a place where it wouldn't piddle all over the place. TO be fair, I think the 302 filter placement sucks too and for the same reason.
            Yes the positions do suck. The Marauder is "fun" to change. Eventually they started (in 04?) putting in a little oil spill trays that funneled a small majority of the spill into one stream. I added this to the marauder. It clipped right on. Don't know if the tray will fit pre 03.
              Free rust-proofing is what it is.
                Oil capacity is 5 quarts for 1991-02. 6 quarts for 03+.
                  4WD Fords with modular engines are even more fun, the front diff is perfectly in the way of the filter as well. The ones I've worked on must have had the spill trays, though. On my '95 GMq I usually drain the pan as much as possible before I loosen the filter, seems to help a little. I run 5-30 synthetic blend and put in 5 quarts, then run it for a bit and top it off. It's supposed to take 5qts but mine usually takes around 5.5.
                  1995 Grand Marquis GS
                  - 156k miles, three-tone until I find my paint
                  1990 Toyota Camry DX - 211k miles, someone else's future barn find
                  1994 Saturn SW2 wagon - wife's car
                  Originally posted by SVT98t
                  I'll make it fit.
                  I own hammers.
