Question About Pull Handle Support
    Does anyone know if the pull handle support shown in the drawing (#6) is the same one that fits a '95 GM driver's front door? Part Number is: F2MY-54266A02-B.
Name:	95 GM Inner Door Panel.gif
    That's a '92 part number. Door panels from 92-94 are the same I think. 95 won't work as far as I know. Could be wrong though.
      #6 looks like the mounting bracket for the back side of the panel.
        Oops. I was thinking the door pull, not the support. My bad.
          Yeah, I may need to replace the support that attaches to the inside of the door and NOT the pull handle itself.
