Anabelle - My 89 Townie HO convo progress
    Here as some pictures of the rebuild. I am doing 1/2 the HO conversion as I am 17 and lack funds, tools, expertise to do the whole thing. Rebuilt Mustang heads, upper intake, throttle body, EGR spacer, headers, h-pipe, flowmaster 40's. Later on I'll add some 3.73's and some 1.7 RR for some more power.
    Nice job!!!
    Keep us updated!
      I will man!! I still have to figure out what exactly I'm going to do with the exhaust. I am currently waiting on the new lower intake . After I get that and I mail off my throttle bodies and EGR spacer to Scott for their adjustments, should be close to gettin done. I cant wait to drive this thing
        Nice work man! Ya it is hard to do things for your car with a 17 year budget. (I know)
          you have a digital dash and a tripminder!!!
          Good job. Sucks working with no budget. been there done that.
          What model President is that? Looks like an AM only rig.
            Nice townie! Good luck on the results - it will be interesting to see what the no-cam HO swap will net in power gains.
            The HO towncar master himself is only a couple hours away, if you need help getting that cam in later
              yes I am eager to see how it will perform, and I will get it dynoed once its running right.
                There is a guy on here with an E7 lopo. I want to say Matthew but I won't swear to that. I think he had to fiddle with the fuel pressure to get it running right, but I don't remember if it ended up with 14 lb injectors and the pressure set high, or 19 lb injectors with the pressure set low.
                  i can give you some hints on the exhaust when you are ready........do you have the mustang h pipe yet? my way it's around 200 bucks tops in parts for the h pipe back duals........you could also do like gadget did with his stock cats.......leaks a tiny bit, but it works lol
                      gadget73, thats the first time I've heard anything about the pressure having to be set to run right :drug: I guess we'll see how it runs with the 14's
                        Some more updated pictures
                        My garage's ventilation system :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
                            That's a nice towny mang, good work so far it looks great.
                            Nick
                            88 Colony Park LS
