'94-'04 Mustang disc brake rotors question.
    If I was collecting brake parts for a braking system upgrade, would the '94-'04 Mustang disc brake rotors fit a box panther or do I need '98-up brake rotors? Anything is better than the 10" rotors.
    '90 Mercury Grand Marquis GS
    5.4L swap coming soon.
    wont work i dont think.......better off just using the 98-02 rotors with the suspension swap those 98-02 rotors are 12.5" btw
      Will '98-'02 panther rotors bolt up to my car's suspension or does everything need to be changed up front to '98-'02 parts? What did you do to give your TC '92-'97 rear discs?
        For the front brake upgrade, I believe the list is as follows (correct me if I miss anything)
        92-95 upper control arms w/ the "pin" style pivot
        95-02 front spindle
        95-02 hub bearing assy
        98-02 caliper bracket
        98-02 rotor
        98-02 caliper
        98-02 hoses, you want the ones for a car w/ traction control. this matters because the driver's side hose is different. the non-traction control cars have a distribution block thing built into the hose, and we don't need or want that.
        lower arm stays the same
        95-02 lower ball joint
        not sure the exact years on the upper BJ, fairly sure 92-02 but match it to the spindle year and it'll be ok.
        I do recall mention of a metric to standard brake line adapter to connect our 3/16 fittings to the metric thread on the brake hose.
        Essentially just rape everything but the upper control arms off a 98-02 car and you'll be OK.
        Upper control arms should be the earlier 90s as they have the same frame mount system as the box, but will take the new style ball joint. These are a cast arm with a bolt-on ball joint as opposed to our stamped steel/riveted ball joint uppers.
