Anyone know howmuch a 9" Quickchange is?
Rearend shite
This topic is closed.
alot hehe..........what are you planning on building? the 8.8 in the panther chassis cars is an excellent unit........it can take lots of punishment
scott
about $1000http://secondhandracing.com/Home.aspx
...shrieks, jumps up and gets nailed by low hanging ceiling fan on high. Picks self up off floor after a 5min trip to lala land and starts calling local junkyards...oops it sunday...they all closed to go give cash to the preacher...2008 Mercury Grand Marquis GS Bone Stock
The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
Originally posted by MercracerIf you think that $1000 is expensive for a complete 9" bolt in for your car, then you need to rethink your project plans.
What are your performance goals?
Originally posted by ButtSlappingPirateI don't even like this loser I am quoting,
Get over it!!!!!!!!
Enough with being a dickhead!
This is a tech board.........let's stick to tech. Put your bullshit aside, and let's get on with it.
Teh Battlefield is where this pissing belongs.
Woah, woah, woah! I had no idea that this would get this crap started. OK my performce goals are for a 9 or 10 second GM. Not to mention a spread in Summit Racing cat!2008 Mercury Grand Marquis GS Bone Stock
Start with putting your car on a diet, building your 9" and the rest of your chassis along with installing your 6 point cage. When your chassis is done, weigh your car, and then move on from there. This will give you your needs for what power level you should build to in order to reach your goals. You might have to look at a mini-tub to fit a large enough tire under your car. Alot of weight there to run a low 10 or high 9. You might want to look at coil overs and ladder bars if you are going to get serious.
Originally posted by MercracerOriginally posted by ButtSlappingPirateI don't even like this loser I am quoting,
Get over it!!!!!!!!
What exactly am I supposed to get over? That you are a weenie?
Okay, I accept the fact that your real name is actually 'Mercracer', and I am now focusing on tech in this section. I have learned my lesson.....
Originally posted by MercracerStart with putting your car on a diet, building your 9" and the rest of your chassis along with installing your 6 point cage. When your chassis is done, weigh your car, and then move on from there. This will give you your needs for what power level you should build to in order to reach your goals. You might have to look at a mini-tub to fit a large enough tire under your car. Alot of weight there to run a low 10 or high 9. You might want to look at coil overs and ladder bars if you are going to get serious.
