Tach wireing?
    Tach wireing?
    Well i finaly got my tach the other day, 5 inch Auto Meter Monster tach but dident come with instructions. I read how to do it on the Auto Meter website but have a few questions.
    1. Were does the green wire go(Tach singnel)? I know to the coil but were at on it?
    2. The white wire were can I splice into to hook it up at? It's for the illumnation.
    3. Weres a good place to hook the hot wire(red one)? Says ingiton switch, is there anywere else?
    http://members.sounddomain.com/sambos86
    My 1979 F-250 Ranger Hi Boy
    33/12.50 BFG Mud Terrians
    390ci with a little bigger cam
    Holly 4 barrel with K&N
    4 Speed with granny gear
    1-the green wire is the tach wire on the coil
    2-illumination wire, you can splice it to the radios illumination(blue with red strip wire)
    3-you can also tap in to ur ignition wire from the radio too(i think its the yellow with black wire)im not 100% on that one.
    this is what i done on my 91' when i put in a sun pro tach, so it should work!
    good luck!
