Thermostat break in
    Thermostat break in
    I just got my thermostat (motorcraft) and wanted to make sure it worked, so I threw it in a pot of boiling water and it looked like it opened up to about just about a half an inch (thickness of my pinky) Is that about normal?
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
    I'd think so. They don't open much, which leads me to believe that's why it's recommended you take them out when doing chemical flushes & stuff.
      Sounds about right.
        How much should the temp be at the thermostat housing? Oil pan??
          Engine running at operating temp, the thermostat housing should be about the same as the coolant itself, running around 200-220F with a 195F thermostat on a stock lopo. Obviously this may be more after a soak time if you come home, park it, and run inside for about 10-20 minutes.
          Never checked the oil pan temp.
            Ok, the motorcraft thermostat says 192 F
              close enough. I couldn't remember exactly what the value was. I knew it was more than 190 and less than 200... so I split the difference.
                I've heard 190, 192, and 195. Whatever I can get in that range seems to do the trick.
                Temp between 185 and 205 seems to be normal, depends where you aim the temperature gizmo, the particulars of the thermostat, the accuracy of the thermometer, planetary alignment and how recently you petted a cat.
                  yeah I aimed at the thermo housing, it was around 196-208
                    I guess I get 220 because it was august here in Texas and the AC was running.
