PDA
View Full Version : tailgate
yucatecd
12-03-2005, 07:19 AM
Dear Wagoneers,
I need the hinges for an '89. Anybody have an extra (good) set? Donald McCaig
gadget73
12-03-2005, 11:42 AM
Are the pins replaceable like the door hinges are? If so, I think you can just cut the old pins out and drive new ones in.
yucatecd
12-03-2005, 11:56 AM
Dear Wagoneers, Mr. Gadget asked?"Are the pins replaceable like the door hinges are? If so, I think you can just cut the old pins out and drive new ones in."
Think of a hinge with a brass bushing which has worn through and the retaining circle is also worn to wobbling. No good to just replace the bushing. Might weld, drill, replace the hinges and will if I can't find a sound used set (no longer available from Ford). Problem here in Virginia is that most of the 89 anythings have been crushed.
Donald McCaig
