Heat....None....Help
    I can't figure out why my heat doesn't work. Chris says that my heater core is fine.... and my thermostat has been change twice... if you have ideas help... he is going to look under my dash... but damn't I am sick of being so cold driving around here... especially when I drive a half hour to work everyday and home without heat... it's flippin' cold! :chainsaw:
    blend door?
      Originally posted by DuceAnAHalf
      blend door?
      I also believe that. It must be stuck not allowing the heat from the core to flow thru the vent. I would make sure you dont have any vacuum leak in the flapper -door vent lines. Is anything hissing?
        yeah, sounds like a blend door to me too. Seems like most 90s panther heat issues are that thing.
