Greetings! Haven't posted in a while!
My 1998 GM LS has been good to me, but this year on its 20th anniversary and its achievement of 100k miles, it has manifested some issues that I'm yet to fully diagnose and treat.
I'm getting a loss of power, mainly when going uphill, in an intermittent manner, sort of like how I heard some people describe it: "Going over rumble strips".
Most of those people spoke of the transmission being the suspect.
For the record, I changed the transmission oil 3 years ago.
For the moment, I will follow a sort of standard procedure, which to my understanding starts with spark plugs, coils, fuel filter, fuel pump, and then the more serious stuff.
Right now I'm a few hours away from changing the spark plugs(I had changed them 3 years ago, the previous ones where the originals). I'll update you all on this later.
In the mean time, I would like to share pictures of something that caught my attention.
Looks like that fuel injector caught some damage from the coolant that was leaking when the intake manifold was cracked(replaced IM 3 years ago). The IM was cracked just next to that FI.
Could the damage be more than cosmetic/external?
Is the O-ring seated between hole and FI enough protection from fluids falling into that space?
More general questions:
How weak are fuel injectors?
How often should they be replaced?
Can they be checked for failure with a volt meter?
