Is it normal for the condensor to drain water even if you haven't had the A/C on? Recently even when I didn't use the heater or ac, I've noticed a small puddle of water under the car passenger side. Thanks....
Condensor Water
Condensor Water
1991 Grey Grand Marquis LS Sedan
61,000 Miles
1998 F150 XLT 4X2 Flareside Fire Engine Red
52,000 Miles
http://www.cardomain.com/id/hdlogisticsTags: None
:slug:
did u have the defroster on? the ac compressor runs in defrost
scott
I thought that might be the answer. I usually turn the defrost/heater off before I park then I noticed the water in the driveway later on. Thanks for the info. This is my first GM so I'm still getting used to some of the quirks.1991 Grey Grand Marquis LS Sedan
61,000 Miles
52,000 Miles
hey are u in the central ontario area?
I'm in Mississauga outside Toronto...1991 Grey Grand Marquis LS Sedan
61,000 Miles
52,000 Miles
