i have a battery on trickl charge and it chaged up to 13.7volts, so i took it off charge and hooked the volt meter up to it ans a 12volt light at 2 0'clock and at 5-530 it droped to 12.7volts and the light dident dim. now it is 9 15 and its still at 12.7volts and the light is still bright, is this a good batt?
battery question
true, i was thinking about that
i need a freakin batt tester, lol
i have a couple deep cycles out of a boat but they are old and shit and heavy, marine cranking what!?!
to see how strong it is, get it to full charge and install it. Hook up a volt meter and watch it while you crank the enging over - it shouldnt go under 10 volts or so.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
when in doubt, go to vatozone and have it load tested!
Marine cranking batteries are not deep cycle. They have the same charge/discharge characteristics as a standard battery. They're heavier because the plates are thicker to take more abuse from wave impact. Usually the "house" or cabin battery is a deep cycle tho. Lower cranking amps, but higher amp-hour ratings.86 Lincoln Town Car (Galactica).
indeed...well i droped the batt into the lincoln and everything seems to be in order
