Starting HO conversion
    Today i started taking apart my engine for the High Output conversion. If anyone has any tips or tricks that would help out a lot. Ill try to get some pics as i go along.
    you can reuse the old headbolts
    '80 Town Coupé
      If you're going to have it apart for several weeks..... maybe coat your cylinder walls and tops of the pistons with oil. :slug:
        dont forget to have the stock egr spacer bored out to 63mm
        also make sure to get 8 injector service kits (o-rings, pintile caps and plastic spacers) i got them from napa for under 20 bucks........also i reccomend felpro permadry valve cover and intake gaskets
        scott
          :bump:Well i started along and got to the the last bolt on the egr spacer with i managed to round off, so now i have to go to napa and get the reverse sockets and get it stripped off, just one of the many bumps in the road i plan on getting myself into, for the throttle body, how to you disconnect it from the car, i have everything on it taken apart and its layin in the engine bay but i can slide the round part inside of it out to get the actual throttle body off. Thanks for the suggestions it will make this go a lot smoother, once i get the upper intake off im going to start taking pictures to post here.
            i realize the bigger bore tb will bring more air in, but on a stock 5.0 what gains could one expect by boring the tb from 50 to 63mm? would it affect the low end any?
            Save a seal, club a liberal.
              hmm
              are you working on it inside the car or did you pull the engine?
              SuperFord Profile
              Support safe sigs
              -sigs should not exceed 600 pixels wide
              -sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
              -Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
              -Total sig size should not exceed 60k
              Remember, only you can prevent sig abuse....
                I have it inside the car
                  If this guy's luck is golden, this car is also his daily driver....
                    hmm
                    pull the engine, rebuild it from the bottom up, paint er purdy
                    SuperFord Profile
                    Support safe sigs
