Got the two way radio antenna installed....
    Finnally got the antenna installed on the rear quarter panel for the two way radio.... Pictures tommorow.. gotta go to work in a minute.... ANYWAY... The idiot that took the antenna off must have used a friggen hole saw to do it.. the hole was just a little bit bigger than the antenna, so when you dropped it in place.. it fell right thru the friggen hole!!! So I had to go get a washer with the right size hole in it.. and then sandwich it in between the antenna mount and the underside of the quarter panel, then carefully screw the antenna on.... but it worked!!! :banana:
    Tom....
