Friday I'm going to go look at 91 F250 supercab 4x4 truck to replace my current rotted out one. If I get the other truck I'm going to strip out the one I've got.
The truck I've got is a 1989 F250 4x4 with a 460 EFI/ 5spd with 4.10 gears. The motor runs liked a raped ape! It has no problem just burning the big 16's that are on the truck. It burns some oil when you get on it hard so I'm going to check the compression and do a leak down test. And most likely will rebuild it if I use it.
What do you guys think, should I swap the 460 EFI engine into my 2dr? I know the extra weight will hurt the handling a little. But I don't have any plans to autoX it. Or should I sell the 460 and sink the cash into more performance parts for my 351W? I know I can make as much if not more power with my 351 and save a bunch of weight but the 460 is a absolute torque monster!! And the way the stock 460 moves my 6000 Lb truck I'd love to see what it could do with some performance mods in my 3500 Lb 2dr.
