If you do not have Electronic temp control, and your fan blows the same on 2 or more speeds or have only 1, or no speed adjustment of the fan...You can unplug your blower fan, and temporarily run 12v to the fan, if it spins your fan is good. Start looking at the blower resistor. It is located under the hood, on the ductwork on the firewall near the passenger side valve cover under the heater hoses. It is held on by 2 screws. You may needa new plug if you have an older type which has been known to melt. But remove this and it is usually evident that these "resistive coils" wound on the unit have broken-burnt apart. This is what changes the voltage to the fan, giving you the different speeds. This is a 15 minute fix usually, The part is usually around $20.
The eatc one is a transistorized unit in the same spot for you "temp control guys"' Cannot be used inplace or regular resistor array with out modifications. Sorry for the huge pics. Thanks to p71interceptor for his pics.
