HELP
    HELP
    I think I have a oil leak starting on my gm.. Its coming from a large golden screw on the oil pump on the bottom. The parts right next to the filter....I dont know what to do except replace the pump...Any help would be appreciated
    R.I.P Linsey Nelson
    Originally posted by MeanVic84
    Chocolate Rain. Some stay dry and others feel the pain.
    This might help
    http://www.p71interceptor.com/oilcooler/index.html
      got a pic? sounds like the oil filter plate-adaptor for the oil lines?
        Its leaking from here
        R.I.P Linsey Nelson
          imports dont suck
            Put some pipe tape on the screw, that should seal it up good.
              Id try that. Be carefull when re-installing it. Pipe threads dont have to be super tight. Just use a few layers of teflon tape and then tighten till snug. if it still leaks the housing might be cracked.
                I would use Permatex thread sealant or equivalent. The tape tears too easily.
                There's also an Oil Filter Adaptor sticky here...in case the leak is dripping from there, but actually coming from somewhere else. Hairline cracks can be hard to see, and that part is under pressure so even a small crack will cause you to lose oil at an alrming rate.
                Good Luck and
                Good Day
                1993 GM LS 244K
                29.5mm PI front bar, ENS greaseable bushings, 21mm rear bar, ENS bushings, endlinks. Black steelies, center caps. Stewart-Warner mechanical oil pressure guage. K&N filter
                1994 Lincoln Mark VIII 144K
                All airbags are now coils/struts. Junk tranny, motor donor car
                Mercury Owners Group
                If you don\'t like what I have to type, don\'t read it. It is only my opinion, nothing more.
                  I would use a thin coat of RTV on the threads instead of teflon pipe tape ....
