View Full Version : Diagnostic trouble codes 2,3 digit and OBD II Listing
Johnnyiroc
01-07-2006, 06:56 PM
(R) = Engine Running test (M) = Memory code (O)=Key On Engine Off test
2 Digit Codes
11
System OK
12
Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
13
(O)
ISC did not respond properly (extends to touch throttle then retracts for KOEO) - ISC
(R)
Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
(M)
ISC sticking, open ITS circuit or TP sticking
14
Ignition pickup (PIP) was erratic - Ignition Systems
E4OD Transmission diesel RPM sensor - Diesel RPM sensor
15
(O)
No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
(M)
KAM (pin 1) was interrupted (was battery disconnected ?)
16
1 9L & 2 5L - Throttle stop set too high - IDLE or Idle Set Procedures
2 3L - RPM's too low - IDLE
(O)
Electronic ignition - IDM circuit fault - Ignition Systems
17
1 9L & 2 5L - Throttle stop set too low - IDLE
18
(R)
Check base timing & advance function - Timing Tests
(M)
Ignition TACH signal erratic - Ignition Systems
Spark Angle Word (SAW) circuit failure (1 9L SFI)
19
(O)
No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
(R)
Erratic idle during test (reset throttle & retest) - Idle Set Procedures
Electronic ignition Cylinder ID sensor/circuit problem - Ignition Systems
21
Engine Coolant Temperature (ECT) sensor out of range - ECT
22
MAP (vacuum) or BARO signal out of range - MAP
23
Throttle sensor out of range or throttle set too high - TPS
24
Intake Air Temperature (IAT) or Vane Air Temperature (VAT) sensor out of range - IAT VAT
25
Knock sensor not tested (ignore if not pinging) - KS
26
Mass Air Flow (MAF) or Vane Air Flow (VAF) out of range - MAF VAF
Transmission Oil Temperature (TOT) sensor out of range, Transmissions
27
Vehicle Speed Sensor problem - VSS
28
Vane Air Temperature (VAT) sensor out of range - VAT
2 3L w/Electronic Ignition - Cyl ID, IDM low or right coil pack failure - Ignition Systems
29
31
(O,R,M)
EVP - EVP signal is/was out of range - EVP
(O,R,M)
EVR - EVP signal is/was low - EVR
(O,R,M)
PFE - PFE signal is/was low - PFE
32
(R)
EVP - EGR not responding properly during test - EVP
(O,R,M)
(R,M)
PFE - PFE shows low pressure, EGR not seating or memory, not seating intermittently - PFE
33
(O,M)
ALL - EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
34
(R)
EVP - EGR did not respond properly during test - EVP
(O,R,M)
EVR - EVP sensor is/was high - EVR
(O,R,M)
PFE - PFE sensor is/was out of range - PFE
35
(R)
EVP - Engine RPM's too low to test EGR system - EVP
(O,R,M)
EVR - EVP sensor signal is/was high - EVR
(O,R,M)
PFE - PFE sensor signal is/was high - PFE
38
Idle Tracking Switch signal was intermittent - ISC
39
Transmission Torque Converter clutch not engaging - Transmissions
41
(R)
System lean - Fuel control
(M)
System was lean for 15 seconds or more (no HO2S switching) - Fuel control
42
(R)
System rich - Fuel control
(M)
System was rich for 15 seconds or more (no HO2S switching) - Fuel control
43
(R)
HO2S sensor not reading (run at 2000 rpm's for 2 minutes and retest - check for HO2S switching)
(M)
Was lean at WOT for 3 seconds or more - Fuel control
44
AIR system inoperative - Air Injection
45
AIR not Diverting (AIRD) - Air Injection
Electronic Ignition - coil primary circuit failure - Ignition Systems
46
AIR Bypass (AIRB) not working - Air Injection
Electronic Ignition - primary circuit failure coil 2 - Ignition Systems
47
Low flow unmetered air (check for small vacuum leaks, injector o'rings, gaskets etc )
E4OD transmission 4x4 switch/circuit problem - Transmissions
48
High flow unmetered air (check for large vacuum leak, inlet hoses etc )
49
Electronic Ignition - spout signal circuit problem - Ignition Systems
Transmission 1/2 shift problem - Transmissions
51
Engine Coolant Temperature (ECT) sensor signal is/was too high - ECT
52
Power Steering Pressure Switch/circuit open - PSP
(R)
Did you turn wheel during test ?
53
Throttle Position sensor too high - TPS
54
Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal high - IAT VAT
55
No or low (under 7 5 V) Key Power to PCM pin 5
56
Vane Air Flow (VAF) or Mass Air Flow (MAF) sensor high - VAF MAF
Transmission Oil Temperature sensor too high - Transmissions
57
Intermittent in Park/Neutral/ Switch or Neutral Pressure switch circuit - PNP or Transmissions
58
Idle Tracking Switch (ITS) signal problem ISC
Vane Air Temperature (VAT) sensor out of range or open - VAT
59
AXOD 4/3 circuit fault - Transmissions
3 0L SHO - Low speed fuel pump circuit problem - Power / Fuel Pump Circuits
Transmission 2/3 shift problem - Transmissions
61
Engine Coolant Temperature (ECT) sensor is or was too low - ECT
62
AXOD (KOEO only) 3/2 circuit short to ground - Transmissions
AXOD (KOEO AND KOER) 4/3 circuit failure - Transmissions
E4OD excessive converter clutch slippage - Transmissions
63
Throttle Position Sensor (TPS) signal too low TPS
64
Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal low or grounded - IAT VAT
65
Check intermittent HO2S (signal or ground) - Fuel Control
(R)
E4OD truck - cycle OD cancel switch after engine ID is received - Transmissions
1984 3 8L ONLY - O, M Battery voltage high (check for electrical system overcharging)
66
Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF
Transmission Oil Temperature (TOT) signal low (possibly grounded) - Transmissions
67
Park/Neutral circuit fault - PNP
Transmission Manual Lever Position (MLP) sensor circuit - Transmissions
(M)
Intermittent Park Neutral Position (PNP) sensor fault - PNP
68
Idle Tracking Switch (ITS) circuit (possibly grounded) - ISC
Vane Air Temperature (VAT) sensor out of range or grounded - VAT
3 8L AXOD -Transmission Temperature Switch (TTS) open - Transmissions
Electronic Transmission - Transmission Oil Temperature (TOT) sensor was overheated -Transmissions
69
AXOD transmission (O) 3/2 switch closed (possible short circuit) - Transmissions
AXOD (M) 3/2 switch open (poss short to power) - Transmissions
E4OD 3/4 shift problem - Transmissions
70
(M)
3 8L AXOD - Data link to instrument cluster fault Service any other EEC codes, erase memory and retest If code is still present refer to instrument cluster diagnosis manual
71
(M)
1 9L TBI, 2 3L TBI, 2 5L TBI - ITS signal was grounded when throttle should have been opening ITS-ISC ISC motor problem or Idle Tracking Switch (ITS) signal wire shorted to ground - ISC
(M)
1 9L MFI - PCM re-initialized Possible electrical noise, case ground or intermittent VPWR problem - VPWR Diagnosis
(M)
3 8L AXOD - Data link to instrument cluster fault - See code 70
72
(R)
No MAP or MAF change in "goose" test - retest, check for frequency or voltage change - MAP MAF
(M)
1 9L MFI - VPWR circuit to PCM was intermittent - VPWR Diagnosis
(M)
2 3L T/C - PCM re-initialized Possible electrical noise, case ground or intermittent VPWR problem - VPWR Diagnosis
(M)
3 8L AXOD - Message center data link circuit fault - See code 70
73
(O)
Rerun test, if 73 is still output replace TPS
(R)
No Throttle Position Sensor (TPS) change in "goose" test Must get at least 25% throttle rotation - TPS
74
Was brake depressed after engine ID was received ?
Brake On Off (BOO) signal open or short to ground - BOO
75
Brake On Off (BOO) signal shorted to power - BOO
76
Vane Air Flow (VAF) did not respond to "goose" test - VAF
77
System did not receive "goose" test - see TESTS
78
(M)
VPWR circuit to PCM was intermittent or the PCM is bad VPWR Diagnosis
79
A/C is on or pin 10 is shorted to power
81
Boost control solenoid - Solenoids
AIRD solenoid - Solenoids and Air Injection
3 0L SHO - Inlet Air Solenoid - Solenoids
82
2 3L TC - Fan Control wire shorted to ground - A/C and Fan Circuits
AIRB solenoid - Solenoids and Air Injection
3 8L SC - Super Charger Bypass Solenoid - Solenoids
83
High Electro Drive Fan circuit fault - A/C and Fan Circuits
EGR Control solenoid - Solenoids
3 0L SHO - Low Speed Fuel Pump Relay circuit - Power / Fuel Pump Circuits
84
EGR Vacuum Regulator - Solenoids
EGR cutoff solenoid - Solenoids
EGR Vent solenoid - Solenoids
85
2 3L T/C Automatic - 3/4-4/3 Shift solenoid - Transmissions
CANP solenoid (ALL 1989) - Solenoids
(M)
1 9L MFI - System has corrected rich condition - Fuel control
86
2 3L or 2 9L Truck - A4LD 3/4 shift solenoid - Transmissions
(M) 1 9L MFI - System has corrected lean condition - Fuel control
87
(O)
Fuel pump circuit fault (check inertia switch) - Power / Fuel Pump Circuits
Vehicles with 2BBL carb - Temperature Compensated Accelerator Pump Solenoid - Solenoids (M) intermittent in fuel pump primary circuit - Power / Fuel Pump Circuits NOTE: On some Escorts with automatic seat belts this code is normal IN MEMORY due to the wiring
88
Throttle Kicker Solenoid - Solenoids
Variable Voltage Choke relay circuit fault - VVC
Fan Control circuit fault - A/C and Fan Circuits
A4LD - Converter Clutch Override solenoid - Transmissions
Electronic Ignition - IDM, DPI or spout circuit fault - Ignition Systems
89
AXOD Torque Converter Control solenoid circuit - Transmissions
Exhaust Heat Control (heat riser) solenoid circuit - Solenoids
91
(R, M) System running lean - Fuel control
Transmission SS 1 circuit/solenoid problem - Transmissions
92
(R)
System running rich - Fuel control
Transmission SS 2 circuit/solenoid problem - Transmissions
93
(O,R)
Throttle linkage binding or bad ISC motor ISC HO2S not reading Fuel control
Transmission TCC circuit/solenoid problem - Transmissions
94
95
(O)
Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
(R)
(M)
Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) - Power / Fuel Pump Circuits
96
(O)
Fuel pump monitor circuit shows no power - Power / Fuel Pump Circuits
(R)
(M)
(Service 87 code first if present) Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits
97
E4OD OD cancel light circuit failure - Transmissions
98
(R)
Did not pass KOEO yet (Get 11 in KOEO first)
Transmission EPC circuit/solenoid failure - Transmissions
99
(R)
ISC needs to learn (Let idle for 2 minutes, Erase memory and retest)
Johnnyiroc
01-07-2006, 10:09 PM
3 Digit codes
111
System checks OK
112
(O,M)
Intake Air Temperature (IAT) sensor is/was low or grounded - IAT
113
(O,M)
IAT sensor is/was high or open - IAT
114
(O,R)
IAT sensor out of range - IAT
116
(O,R)
Engine Coolant (ECT) sensor out of range - ECT
117
(O,M)
ECT sensor is/was low or grounded - ECT
118
(O,M)
ECT sensor is/was high or open - ECT
121
(O,R,M)
Throttle Position (TP) sensor out of range - TPS
122
(O,M)
TP low (possibly grounded or open circuit) - TPS
123
(O,M)
TP is/was high or short to power - TPS
124
(M)
TP voltage was higher than expected - Fuel control
125
(M)
TP voltage was lower than expected - Fuel control
126
(O,R,M)
MAP or BARO sensor out of range - ">MAP
128
(M)
MAP vacuum has not been changing - check vacuum lines - ">MAP
129
(R)
No MAP or Mass Air Flow sensor change during "goose" test - MAP MAF
136
(R)
Oxygen sensor not switching/system lean Left or Front HO2S - Fuel control
137
(R)
Oxygen sensor not switching/system rich Left or Front HO2S - Fuel control
138
(R)
Fault in Cold Start Injector circuit - Fuel control
139
(M)
Oxygen sensor not switching Left or Front HO2S - Fuel control
144
(M)
Oxygen sensor not switching Single, Right or Rear HO2S - Fuel control
157
(R,M)
Mass Air Flow signal is/was low or grounded - MAF
158
(O,R,M)
MAF sensor is/was high or short to power - MAF
159
(O,R)
MAF sensor is/was out of range - MAF
167
(R)
No Throttle Position sensor change in "goose" test (must get at least 25% rotation) - TPS
171
(M)
Oxygen sensor not switching - system was at adaptive limits - Single, Right or Rear HO2S - Fuel control
172
(R,M)
Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
173
(R,M)
Oxygen sensor not switching - system is or was rich - Single, Right or Rear HO2S - Fuel control
174
(M)
Oxygen sensor was slow in switching Single, Right or Rear HO2S - Fuel control
175
(M)
Oxygen sensor not switching - system was at adaptive limits - Left or Front HO2S - Fuel control
176
(M)
Oxygen sensor not switching - system is or was lean Left or Front HO2S - Fuel control
177
(M)
Oxygen sensor not switching - system was rich Left or Front HO2S - Fuel control
178
(M)
Oxygen sensor was slow in switching Left or Front HO2S - Fuel control
179
(M)
Fuel system was rich at part throttle Single, Right or Rear HO2S - Fuel control
181
(M)
Fuel system was lean at part throttle Single, Right or Rear HO2S - Fuel control
182
(M)
Fuel system was rich at idle Single, Right or Rear HO2S - Fuel control
183
(M)
Fuel system was lean at idle Single, Right or Rear HO2S - Fuel control
184
(M)
Mass Air (MAF) output higher than expected - Fuel control
185
(M)
Mass Air (MAF) output lower than expected - Fuel control
186
(M)
Injector pulse width longer than expected or Mass Air Flow (MAF) lower than expected - Fuel control
187
Injector pulse width shorter than expected or Mass Air Flow (MAF) higher than expected - Fuel control
188
(M)
Fuel system was rich at part throttle - Left or Front HO2S - Fuel control
189
(M)
Fuel system was lean at part throttle - Left or Front HO2S - Fuel control
191
(M)
Fuel system was rich at idle - Left or Front HO2S - Fuel control
192
(M)
Fuel system was lean at idle - Left or Front HO2S - Fuel control
193
Failure in Flexible Fuel (FF) sensor circuit - Fuel control
194
(M)
Perform cylinder balance test to check for inoperative injectors
195
(M)
211
(M)
Ignition PIP signal was erratic or missing - Ignition Systems
212
(M)
Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault - Ignition Systems
213
(R)
Ignition SPOUT or SAW circuit open or shorted - Ignition Systems
214
(M)
Error in Cylinder ID (CID) circuit or signal - Ignition Systems
215
(M)
Primary circuit failure - ignition coil 1 - Ignition Systems
216
(M)
Primary circuit failure - ignition coil 2 - Ignition Systems
217
(M)
Primary circuit failure - ignition coil 3 - Ignition Systems
218
(M)
IDM signal open or high or left coil pack failure - Ignition Systems
219
(M)
SPOUT circuit failure, timing defaulted to 10 degrees - follow code 213 diagnosis
222
(M)
IDM open or high or right coil pack failure - Ignition Systems
223
(M)
Dual Plug (DPI), SPOUT or IDM circuit fault - Ignition Systems
224
(M)
Failure in ignition coil primary circuit - Ignition Systems
225
(R)
226
(O)
Ignition Diagnostic Monitor (IDM) signal fault - Ignition Systems
232
(M)
EI primary coil circuit failure - Ignition Systems
238
(M)
EI primary circuit failure - ignition coil 4 - Ignition Systems
311
(R)
AIR system not working - Single, Right or Rear HO2S - Air Injection
312
(R)
AIR not diverting - Air Injection
313
(R)
AIR not bypassing - Air Injection
314
(R)
AIR inoperative, Left or Front HO2S - Air Injection
326
(R,M)
Pressure Feedback EGR shows low pressure EGR not seating or not seating intermittantly - PFE
327
(O,R,M)
EGR feedback signal is/was low - EVR or PFE
328
(O,R,M)
EGR Valve Position (EVP) is/was low - EVR
332
(R,M)
EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE
334
(O,R,M)
335
(O)
EGR feedback signal is/was out of range - EVR or PFE
336
(O,R,M)
PFE sensor signal is/was was high - ">PFE
337
(O,R,M)
EGR feedback signal is/was was high - EVR
338
(M)
Cooling system did not heat up (check cooling system / thermostat operation)
339
(M)
Cooling system overheated (check cooling system / thermostat operation)
341
(O)
Octane jumper installed (information only code to notify you if it is installed)
411
(R)
Idle speed system not controlling idle properly (generally idle too high) - ISC
412
(R)
Idle speed system not controlling idle properly (generally idle too low) - ISC
452
(M)
Vehicle Speed Sensor (VSS) problem
511
(O)
No power to PCM pin 1 or bad PCM (processor)
512
(M)
Memory power (PCM pin 1) was interrupted - Was battery disconnected ?
513
(O)
Replace processor (PCM) (internal failure)
519
(O)
PSP switch/circuit open - PSP h Pedal Position (CPP) circuit fault - PNP
528
(M)
System shows voltage at pin 10 (is A/C on ?) or pin 30 (PNP, CPP switch) - PNP
529
(M)
Data Communications Link to processor failure Service any EEC codes, erase memory and retest If code is still present refer to instrument cluster diagnosis manual
533
(M)
Data Communications Link to instrument cluster failure - see 529
536
(O,R,M)
Brake On Off open or shorted to ground - BOO
538
(R)
System did not receive "goose" test - TESTS
539
(O)
System shows voltage at PCM pin 10 Is A/C on ?
542
(O,M)
Fuel pump open, bad ground or always on - - Power / Fuel Pump Circuits
543
(O)
(M)
(Service 556 code first if present) Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits
551
Problem in Intake Manifold Runner Control (IMRC) solenoid/circuit - Solenoids
552
(O)
AIRB solenoid/circuit failure - Solenoids
553
(O)
AIRD solenoid/circuit failure - Solenoids
554
(O)
Fuel Press Regulator Control solenoid/circuit fault - Power / Fuel Pump Circuits
556
(O,M)
Fuel pump relay primary circuit fault - Power / Fuel Pump Circuits
557
(O,M)
Low speed pump relay primary circuit fault - Power / Fuel Pump Circuits
558
(O)
EGR vacuum regulator solenoid/circuit failure - EVR or PFE or Solenoids
559
(O)
A/C relay primary circuit fault - A/C and Fan Circuits
563
(O)
High Fan Control (HFC) circuit failure - A/C and Fan Circuits
564
(O)
Fan Control (FC) circuit failure - A/C and Fan Circuits
565
(O)
Canister Purge 1 solenoid/circuit failure - Solenoids
566
(O)
transmission 3/4 shift solenoid/circuit - Transmissions
569
(O)
Canister Purge 2 solenoid/circuit failure - Solenoids
578
(M)
A/C pressure sensor VREF short to ground - A/C and Fan Circuits
579
(M)
ACP sensor did not change with A/C on - A/C and Fan Circuits
581
(M)
Cooling fan current was excessive - A/C and Fan Circuits
582
(O)
Open cooling fan circuit - A/C and Fan Circuits
583
(M)
Fuel pump current was excessive - Power / Fuel Pump Circuits
584
(M)
Open power ground circuit - Power / Fuel Pump Circuits
585
(M)
A/C clutch current was excessive - A/C and Fan Circuits
586
(M)
Open circuit in A/C clutch - A/C and Fan Circuits
587
(O, M)
Communication problem between PCM and Variable Control Relay Module (VCRM) - Power / Fuel Pump Circuits
617
(M)
Transmission shift failure (1/2 shift) - Transmissions
618
(M)
Transmission shift failure (2/3 shift) - Transmissions
619
(M)
Transmission shift failure (3/4 shift) - Transmissions
621
(O)
Solenoid/circuit failure - shift solenoid 1 - Transmissions
622
(O)
Solenoid/circuit failure - shift solenoid 2 - Transmissions
624
(O,M)
Solenoid/circuit failure -Electronic Pressure Control (EPC) current is high - Transmissions
625
(O,M)
Solenoid/circuit failure - Electronic Pressure Control (EPC) current is low - Transmissions
626
(O)
Transmission Coast Clutch (CCS) Solenoid/circuit fault - Transmissions
627
(O)
Torque Converter Clutch circuit fault - Transmissions
628
(M)
Excessive converter clutch slippage - Transmissions
629
(O,M)
631
(O)
Overdrive Cancel Light circuit problem - Transmissions
632
(R)
E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
633
(O)
4x4L switch should be in 4x2 or 4x4 high for the test
634
(O,M)
Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault Electronic shift transmission - Manual Lever Position (MLP) sensor out of range in Park-Transmissions
636
(O,R)
Transmission Oil Temperature (TOT) sensor out of range - Transmissions
637
(O,M)
TOT sensor is/was high or open - Transmissions
638
(O,M)
TOT sensor is/was low or grounded - Transmissions
639
(R,M)
Transmission Speed sensor (TSS) circuit fault - Transmissions
641
(O)
Transmission solenoid/circuit failure Shift Solenoid 3 - Transmissions
643
(O,M)
Torque Converter Clutch (TCC) circuit - Transmissions
645
(M)
Transmission 1st gear failure - Transmissions
646
(M)
Transmission 2nd gear failure - Transmissions
647
(M)
Transmission 3rd gear failure - Transmissions
648
(M)
Transmission 4th gear failure - Transmissions
649
(M)
Transmission EPC system failure - Transmissions
651
(M)
Transmission EPC solenoid/circuit fault - Transmissions
652
(O)
Torque Converter Clutch (TCC) circuit fault - Transmissions
654
(O)
Transmission selector not in PARK - Transmissions
656
(M)
Torque Converter Clutch (TCC) slip - Transmissions
657
(M)
Transmission temperature was excessive - Transmissions
Johnnyiroc
01-07-2006, 10:12 PM
EEC-V Basics -codes
P0102
MAF Circuit Low Input
P0103
MAF Circuit High Input
P0106
BARO Sensor Circuit Performance
P0107
BARO Sensor Low Voltage Detected
P0108
BARO Sensor High Voltage Detected
P0109
BARO Sensor Circuit Intermittent
P0112
IAT Circuit Low Input
P0113
IAT Circuit High Input
P0117
ECT Circuit Low Input
P0118
ECT Circuit High Input
P0121
TP Sensor Circuit Performance Problem
P0122
TP Sensor Circuit Low Input
P0123
TP Sensor Circuit High Input
P0125
Insufficient Coolant Temperature To Enter Closed Loop
P0126
Insufficient Coolant Temperature For Stable Operation
P0127
Air Intake Temperature To High
P0131
Upstream HO2S Circuit Out Of Range Low Voltage, Bank No. 1
P0132
Upstream HO2S Circuit Voltage High, Bank No. 1
P0133
Upstream HO2S Circuit Slow Response, Bank No. 1
P0135
Upstream HO2S Heater Circuit Fault, Bank No. 1
P0136
Downstream HO2S Circuit Fault, Bank No. 1
P0138
Downstream HO2S Circuit Voltage High, Bank No. 1
P0140
Downstream HO2S Circuit Faulty, Bank No. 1
P0141
Downstream HO2S Heater Circuit Fault, Bank No. 1
P0151
Upstream HO2S Circuit Out Of Range Low Voltage, Bank No. 2
P0152
Upstream HO2S Circuit Voltage High, Bank No. 2
P0153
Upstream HO2S Circuit Slow Response, Bank No. 2
P0155
Upstream HO2S Circuit Fault, Bank No. 2
P0156
Downstream HO2S Circuit Fault, Bank No. 2
P0158
Downstream HO2S Circuit Voltage High, Bank No. 2
P0160
P0161
Downstream HO2S Heater Circuit Fault, Bank No. 2
P0171
System Too Lean, Bank No. 1
P0172
System Too Rich, Bank No. 1
P0174
System Too Lean, Bank No. 2
P0175
System Too Rich, Bank No. 2
P0176
Flexible Fuel Sensor
P0180
Engine Fuel Temperature Sensor Circuit, Electrical Fault
P0181
P0182
P0183
P0186
Engine Fuel Temperature Sensor B Circuit
P0187
P0188
P0190
Fuel Rail Pressure Sensor Signal Low
P0191
Fuel Rail Pressure Sensor Circuit Performance
P0192
Fuel Rail Pressure Sensor Circuit Low Input
P0193
Fuel Rail Pressure Sensor Circuit High Input
P0201–P0212
Injector Circuits
P0217 P0218
Engine Coolant Overtemp Condition
P0222
Throttle Position Sensor B Circuit Input Low
P0223
Throttle Position Sensor B Circuit Input High
P0230
Fuel Pump Primary Circuit Fault
P0231
Fuel Pump Secondary Circuit Low
P0232
Fuel Pump Secondary Circuit High
P0234
Supercharger Overboost Condition
P0243
Supercharger Bypass Solenoid Malfunction
P0298
Engine Oil Over Temperature Condition
P0300
Random Misfire Detected
P0301–P0310
Misfire Detected Cylinders 1–10
P0320
Ignition Engine Speed Input Circuit Fault
P0325
A Spark Knock Occurred & Sensor Circuitry Did Not Respond
P0326
Spark Knock Has Not Been Sensed
P0330
P0331
P0340
CMP Sensor Circuit Fault
P0350
Ignition Coil Primary Circuit Fault
P0351-P0360
Ignition Coil (A through J) Primary/Secondary Circuit Fault
P0385
Misfire Detection Sensor Circuit Failure
P0400
EGR Flow Faulty
P0401
Insufficient EGR Flow
P0402
EGR Flow Excessive At Idle
P0411
Secondary Air Injection System Flow Improper
P0412
Secondary Air Injection System Control Valve Faulty
P0413
Secondary Air Injection Solenoid Did Not Change When Activated
P0414
P0416
P0417
P0420
Catalyst System Efficiency Below Limit, Bank No. 1
P0421
P0430
Catalyst System Efficiency Below Limit, Bank No. 2
P0431
P0440
Evaporative Emission Purge Control Solenoid Damaged
P0442
Leak In Evaporative System Detected
P0443
EVAP Canister Purge Control Solenoid Or Valve Faulty
P0446
Evaporative Emission Control System Vent Control Malfunction
P0451
Fuel Tank Pressure Circuit Noisy
P0452
Fuel Tank Pressure Signal Circuit Input Below Minimum
P0453
Fuel Tank Pressure Signal Circuit Input Above Maximum
P0455
Leak Or Blockage Detected In Evaporative Emission Control System
P0456
Very Small Leak Detected in Evaporative Emission Control System
P0457
Fuel Filler Cap Loose Or Off
P0460
Fuel Level Sensor Input Circuit Malfunction
P0500
Vehicle Speed Sensor Fault
P0501
Vehicle Speed Sensor Range/Performance
P0503
VSS Intermittent
P0505
Idle Air Control Valve System Fault
P0552
Power Steering Pressure Sensor Shorted To Power
P0553
P0602
Control Module Programming Error
P0603
PCM KAM Test Error
P0605
PCM Read Only Memory Error
P0703
Brake On/Off Switch Input Fault
P0704
Clutch Pedal Position Switch Input Circuit Fault
P0705
Transmission Range Sensor Out Of Self Test Range Or Shorted To Ground
P0707
Transmission Range Sensor Circuit Low Input
P0708
Transmission Range Sensor Circuit High Input
P0712
Transmission Fluid Temperature Sensor Circuit Input Low
P0713
Transmission Fluid Temperature Sensor Circuit Input High
P0715
turbine Shaft Speed Sensor Circuit Fault
P0717
Transmission Concern
P0720
Output Shaft Speed Sensor Circuit
P0721
P0722
No Signal From Output Shaft Speed Sensor
P0723
Output Shaft Speed Sensor Circuit Intermittent Failure
P0731
Improper Ratio For First Gear
P0732
Improper Ratio For Second Gear
P0733
Improper Ratio For Third Gear
P0734
Improper Ratio For Fourth Gear
P0735
P0736
Improper Ratio For Reverse Gear
P0741
TCC System Improper Mechanical Performance
P0743
Torque Converter Clutch System Electrical Failure
P0746
Electronic Pressure Control Solenoid Performance
P0750
Shift Solenoid No. 1 Circuit
P0751
Shift Solenoid No. 1 Performance
P0755
Shift Solenoid No. 2 Circuit
P0756
Shift Solenoid No. 2 Performance
P0760
Shift Solenoid No. 3 Circuit
P0761
Shift Solenoid No. 3 Performance
P0765
P0781
1 To 2 Shift Error
P0782
2 To 3 Shift Error
P0783
3 To 4 Shift Error
P0784
4 To 5 Shift Error
P0796
P0797
P0799
P0812
Reverse Switch Input Circuit Malfunction
P0813
P0815
P1000
OBD II Monitor Testing Incomplete
P1001
KOER Test Cannot Be Completed
P1039
Vehicle Speed Signal Missing Or Improper
P1051
Brake Switch Signal Missing Or Improper
P1100
Mass Air Flow Sensor Intermittent
P1101
Mass Air Flow Sensor Out Of Self Test Range
P1109
IAT Sensor 2 Intermittent
P1112
IAT Sensor Intermittent
P1114
IAT Sensor 2 Circuit Low Input
P1115
IAT Sensor 2 Circuit High Input
P1116
ECT Sensor Out Of Self Test Range
P1117
ECT Sensor Intermittent
P1120
TP Sensor Out Of Range Too Low
P1121
TP Sensor Inconsistent With MAF Sensor
P1124
TP Sensor Out Of Self Test Range
P1125
TP Sensor Intermittent
P1127
HO2S Heater Not On During KOER Test
P1128
HO2S Sensor Signals Swapped
P1129
P1130
Lack Of Upstream HO2S Switch, Adaptive Fuel Limit, Bank No. 1
P1131
Lack Of Upstream HO2S Switch, Sensor Indicates Lean, Bank No. 1
P1132
Lack Of Upstream HO2S Switch, Sensor Indicates Rich, Bank No. 1
P1135
Ignition Switch Signal Missing Or Improper
P1137
Lack Of Downstream HO2S Switch, Sensor Indicates Lean, Bank No. 1
P1138
Lack Of Downstream HO2S Switch, Sensor Indicates Rich, Bank No. 1
P1150
Lack Of Upstream HO2S Switch, Adaptive Fuel Limit, Bank No. 2
P1151
Lack Of Upstream HO2S Switch, Sensor Indicates Lean, Bank No. 2
P1152
Lack Of Upstream HO2S Switch, Sensor Indicates Rich, Bank No. 2
P1157
Lack Of Downstream HO2S Switch, Sensor Indicates Lean, Bank No. 2
P1158
Lack Of Downstream HO2S Switch, Sensor Indicates Rich, Bank No. 2
P1168
Fuel Rail Pressure Sensor In Range But Low
P1169
Fuel Rail Pressure Sensor In Range But High
P1180
Fuel Delivery System Low
P1181
Fuel Delivery System High
P1183
Engine Oil Temperature Sensor Circuit Malfunction
P1184
Engine Oil Temperature Sensor Out Of Self-Test Range
P1220
Series Throttle Control Fault
P1224
Throttle Position Sensor B Out Of Self Test Range
P1229
Supercharger Intercooler Pump Not Operating
P1230
Open Power To Fuel Pump Circuit
P1231
High Speed Fuel Pump Relay Activated
P1232
Low Speed Fuel Pump Primary Circuit Failure
P1233
Fuel Pump Driver Module Off Line
P1234
P1235
Fuel Pump Control Out Of Range
P1236
P1237
Fuel Pump Secondary Circuit Fault
P1238
P1244
Alternator Load Input Low
P1245
Alternator Load Input High
P1246
Alternator Load Input Problem
P1250
Lack Of Power To FPRC Solenoid
P1260
THEFT Detected, Engine Disabled
P1270
Engine RPM Or Vehicle Speed Limiter Reached
P1285
Cylinder Head Over Temperature Sensed
P1288
Cylinder Head Temperature Sensor Out Of Self Test Range
P1289
Cylinder Head Temperature Sensor Signal Greater Than Self Test Range
P1290
Cylinder Head Temperature Sensor Signal Less Than Self Test Range
P1299
Cylinder Head Temperature Sensor Detected Engine Overheating Condition
P1309
Misfire Detection Monitor Not Enabled
P1351
Ignition Diagnostic Monitor Circuit Input Fault
P1352
Ignition Coil A Primary Circuit Fault
P1353
Ignition Coil B Primary Circuit Fault
P1354
Ignition Coil C Primary Circuit Fault
P1355
Ignition Coil D Primary Circuit Fault
P1356
Loss of Ignition Diagnostic Module Input To PCM
P1358
Ignition Diagnostic Monitor Signal Out Of Self Test Range
P1359
Spark Output Circuit Fault
P1364
P1380
Variable Cam Timing Solenoid Valve Circuit Short Or Open
P1381
Variable Cam Timing Advance Excessive
P1383
P1390
Octane Adjust Out Of Self Test Range
P1400
Differential Pressure Feedback Electronic Sensor Circuit Low Voltage
P1401
Differential Pressure Feedback Electronic Sensor Circuit High Voltage
P1403
Differential Pressure Feedback Electronic Sensor Hoses Reversed
P1405
Differential Pressure Feedback Electronic Sensor Circuit Upstream Hose
P1406
Differential Pressure Feedback Electronic Sensor Circuit Downstream Hose
P1407
EGR No Flow Detected
P1408
EGR Flow Out Of Self Test Range
P1409
EGR Vacuum Regulator Circuit Malfunction
P1410
EGR Barometric Pressure Sensor VREF Voltage
P1411
Secondary Air Is Not Being Diverted
P1413
Secondary Air Injection System Monitor Circuit Low Voltage
P1414
Secondary Air Injection System Monitor Circuit High Voltage
P1442
P1443
Evaporative Emission Control System, Vacuum System, Purge Control Solenoid Or Purge Control Valve Fault
P1444
Purge Flow Sensor Circuit Input Low
P1445
Purge Flow Sensor Circuit Input High
P1450
Inability Of Evaporative Emission Control System To Bleed Fuel Tank
P1451
Lack Of Response From Passive Anti-Theft System Module, Engine Disabled
P1452
P1455
Substantial Leak Or Blockage In Evaporative Emission Control System
P1460
Wide Open Throttle Air Conditioning Cutoff Circuit Malfunction
P1461
Air Conditioning Pressure Sensor Circuit Low Input
P1462
Air Conditioning Pressure Sensor Circuit high Input
P1463
Air Conditioning Pressure Sensor Insufficient Pressure Change
P1464
A/C Demand Out Of Self Test Range
P1469
Low A/C Cycling Period
P1473
Fan Secondary High With Fans Off
P1474
Low Fan Control Primary Circuit
Hydraulic Cooling Fan Primary Circuit Failure
P1477
Medium Fan Control Primary Function Failure
P1479
High Fan Control Primary Circuit
P1480
Fan Secondary Low With Low Fans On
P1481
Fan Secondary Low With High Fans On
P1483
Power To Cooling Fan Exceeded Normal Draw
P1484
Variable Load Control Module Pin 1 Open
P1500
Vehicle Speed Sensor Intermittent
P1501
VSS Out Of Self-Test Range
P1502
Invalid Or Missing Vehicle Speed Message Or Brake Data (1998)
VSS Intermittent (1999)
P1504
IAC Circuit Malfunction
P1505
IAC System At Adaptive Clip
P1506
IAC Over Speed Error
P1507
IAC Under Speed Error
P1512
Intake Manifold Runner Control Stuck Closed
P1513
P1516
Intake Manifold Runner Control Input Error
P1517
P1518
Intake Manifold Runner Control Fault, Stuck Open
P1519
Intake Manifold Runner Control Stuck Open
P1520
Intake Manifold Runner Control Circuit Fault
P1530
Open Or Short To A/C Compressor Clutch Circuit
P1537
P1538
P1539
Power To A/C Compressor Clutch Circuit Exceeded Normal Current Draw
P1549
IMT Valve Vacuum Actuator Connection (1996-98)
Intake Manifold Communications Control Circuit Malfunction (1999)
P1550
Power Steering Pressure Sensor Out Of Self Test Range
P1565
Speed Control System Concern
P1566
P1567
P1568
P1572
Brake Pedal Switch Circuit
P1605
PCM Keep Alive Memory Test Error
P1625
Voltage To Vehicle Load Control Module Fan Circuit Not Detected
P1626
Voltage To Vehicle Load Control Module Circuit Not Detected
P1633
Keep Alive Memory Power Voltage Low
P1635
Tire/Axle Ratio Out Of Acceptable Range
P1639
Vehicle ID Block Not Programmed Or Is Corrupt
P1640
Powertrain DTCs Available In Another Module
P1641
Fuel Pump Driver Module Concern
P1650
Power Steering Pressure Switch Out Of Self Test Range
P1651
Power Steering Pressure Switch Input Fault
P1700
P1701
Reverse Engagement Error
P1702
P1703
Brake On/Off Switch Out Of Self Test Range
P1704
P1705
Manual Lever Position Sensor Out Of Self Test Range
P1709
Park Or Neutral Position Switch Out Of Self Test Range
P1710
P1711
Transmission Fluid Temperature Sensor Out Of Self Test Range
P1713–P1728
P1729
4x4 Low Switch Error
P1740
P1741
Torque Converter Clutch Control Error
P1742
Torque Converter Clutch Solenoid Faulty
P1743
P1744
Torque Converter Clutch System Stuck In Off Position
P1745
P1746
Electronic Pressure Control Solenoid, Open Circuit
P1747
Electronic Pressure Control Solenoid, Short Circuit
P1749
Electronic Pressure Control Solenoid Failed Low
P1751
P1754
Coast Clutch Solenoid Circuit Malfunction
P1756
P1760
P1761
P1762
P1767
P1780
Transmission Control Switch Circuit Out Of Self Test Range
P1781
4x4 Low Switch Out Of Self Test Range
P1783
Transmission Over Temperature Condition
P1784–P1789
P1900
P1901
U1020
Module Communications Network Concern
SCP Invalid Or Missing Data For A/C Compressor Clutch (1998-99)
U1021, U1073 & U1131
Failure In Communication Between PCM & Variable Load Control Module (1994-97)
U1039
SCP Invalid Or Missing Data For Vehicle Speed (1998-2001)
U1039, U1051, U1135 & U1451
Module Communications Network Concern (1994-97)
U1041
U1051
SCP Invalid Or Missing Data For Brakes (1998-2001)
U1131
SCP Invalid Or Missing Data For Fuel System (1998-2001)
U1147
SCP Invalid Or Missing Data For Vehicle Security (1998-99)
U1256
Variable Load Control Module Concern
U1262
SCP Communications Bus Fault
U1451
SCP Invalid Or Missing Data For Anti-Theft Module (1998-2001)
U1850
Invalid Or Missing Fuel system Data
U2243
SCP Invalid Or Missing Data For Exterior Environment (1998-2001)
UXXXX
PCM Concern (1994-97)
U DTCs Received During Self-Test Of Another Module (1998-2001)
Johnnyiroc
01-07-2006, 10:14 PM
Secondary, more complete listing with c-codes
P0100 Mass Air Flow Circuit Malfunction
P0101 Mass Air Flow Circuit Range/Performance Problem
P0102 MAF Circuit Low Input
P0103 MAF Circuit High Input
P0104 MAF Circuit Intermittent
P0105 MAP/BP Circuit Malfunction
P0106 MAP/BP Sensor Range/Performance Problem
P0107 MAP/BP Sensor Low Input
P0108 MAP/BP Sensor High Input
P0109 MAP/BP Circuit Intermittent
P0110 IAT Circuit Malfunction
P0111 IAT Circuit Range/Performance Problem
P0112 IAT Circuit Low Input
P0113 IAT Circuit High Input
P0114 IAT Circuit Intermittent
P0115 ECT Circuit Malfunction
P0116 ECT Circuit Range/Performance Problem
P0117 ECT Circuit Low Input
P0118 ECT Circuit High Input
P0119 ECT Intermittent
P0120 TP Sensor A Circuit Malfunction
P0121 TP Sensor A Circuit Range/Performance Problem
P0122 TP Sensor A Circuit Low Input
P0123 TP Sensor A Circuit High Input
P0124 TP Sensor A Circuit Intermittent
P0125 Insufficient Coolant Temp For Closed Loop Fuel Control
P0126 Insufficient Coolant Temp For Stable Operation
P0128 Coolant Thermostat Malfunction
P0130 Heated O2 Sensor Circuit Malfunction (Bank 1, Sensor 1)
P0131 Heated O2 Circuit Low Voltage (Bank 1, Sensor 1)
P0132 Heated O2 Sensor Circuit High Voltage (Bank 1, Sensor 1)
P0133 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 1)
P0134 Heated O2 Sensor Circuit No Activity Detected (Bank 1, Sensor 1)
P0135 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
P0136 Heated O2 Sensor Circuit Malfunction (Bank 1, Sensor 2)
P0137 Heated O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2)
P0138 Heated O2 Sensor Circuit High Voltage (Bank 1, Sensor 2)
P0139 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 2)
P0140 Heated O2 Sensor Circuit No Activity Detected (Bank 1, Sensor 2)
P0141 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
P0142 Heated O2 Sensor Circuit Malfunction (Bank 1, Sensor 3)
P0143 Heated O2 Sensor Circuit Low Voltage (Bank 1, Sensor 3)
P0144 Heated O2 Sensor Circuit High Voltage (Bank 1, Sensor 3)
P0145 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 3)
P0146 Heated O2 Sensor Circuit No Activity Detected (Bank 1, Sensor 3)
P0147 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 3)
P0150 Heated O2 Sensor Circuit Malfunction (Bank 2, Sensor 1)
P0151 Heated O2 Sensor Circuit Low Voltage (Bank 2, Sensor 1)
P0152 Heated O2 Sensor Circuit High Voltage (Bank 2, Sensor 1)
P0153 Heated O2 Sensor Circuit Slow Response (Bank 2, Sensor 1)
P0154 Heated O2 Sensor Circuit No Activity Detected (Bank 2, Sensor 1)
P0155 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 1)
P0156 Heated O2 Sensor Circuit Malfunction (Bank 2, Sensor 1)
P0157 Heated O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2)
P0158 Heated O2 Sensor Circuit High Voltage (Bank 2, Sensor 2)
P0159 Heated O2 Sensor Circuit Slow Response (Bank 2, Sensor 2)
P0160 Heated O2 Sensor Circuit No Activity Detected (Bank 2, Sensor 2)
P0161 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 2)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Fault
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0195 Engine Oil Temperature Sensor Circuit Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder #1
P0202 Injector Circuit Malfunction - Cylinder #2
P0203 Injector Circuit Malfunction - Cylinder #3
P0204 Injector Circuit Malfunction - Cylinder #4
P0205 Injector Circuit Malfunction - Cylinder #5
P0206 Injector Circuit Malfunction - Cylinder #6
P0207 Injector Circuit Malfunction - Cylinder #7
P0208 Injector Circuit Malfunction - Cylinder #8
P0209 Injector Circuit Malfunction - Cylinder #9
P0210 Injector Circuit Malfunction - Cylinder #10
P0211 Injector Circuit Malfunction - Cylinder #11
P0212 Injector Circuit Malfunction - Cylinder #12
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Overtemp Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch B Performance Problem
P0222 Throttle Position Sensor B Circuit Low Input
P0223 Throttle Position Sensor B Circuit High Input
P0224 Throttle Position Sensor B Intermittent
P0225 Throttle Position Sensor C Circuit Malfunction
P0227 Throttle Position Sensor C Circuit Low Input
P0228 Throttle Position Sensor C Circuit High Input
P0229 Throttle Position Sensor C Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Circuit Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Wastegate Solenoid A Malfunction
P0244 Wastegate Solenoid A Range/Performance
P0245 Wastegate Solenoid A Low
P0246 Wastegate Solenoid A High
P0247 Wastegate Solenoid B Malfunction
P0248 Wastegate Solenoid B Range/Performance
P0249 Wastegate Solenoid B Low
P0250 Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control A Malfunction
P0252 Injection Pump Fuel Metering Control A Range/Performance
P0253 Injection Pump Fuel Metering Control A Low
P0254 Injection Pump Fuel Metering Control A High
P0255 Injection Pump Fuel Metering Control A Intermittent
P0256 Injection Pump Fuel Metering Control B Malfunction
P0257 Injection Pump Fuel Metering Control B Range/Performance
P0258 Injection Pump Fuel Metering Control B Low
P0259 Injection Pump Fuel Metering Control B High
P0260 Injection Pump Fuel Metering Control B Intermittent
P0261 Injector Circuit Low - Cylinder #1
P0262 Injector Circuit High - Cylinder #1
P0263 Cylinder #1 Balance Fault
P0264 Injector Circuit Low - Cylinder #2
P0265 Injector Circuit High - Cylinder #2
P0266 Cylinder #2 Balance Fault
P0267 Injector Circuit Low - Cylinder #3
P0268 Injector Circuit High - Cylinder #3
P0269 Cylinder #3 Balance Fault
P0270 Injector Circuit Low - Cylinder #4
P0271 Injector Circuit High - Cylinder #4
P0272 Cylinder #4 Balance Fault
P0273 Injector Circuit Low - Cylinder #5
P0274 Injector Circuit High - Cylinder #5
P0275 Cylinder #5 Balance Fault
P0276 Injector Circuit Low - Cylinder #6
P0277 Injector Circuit High - Cylinder #6
P0278 Cylinder #6 Balance Fault
P0279 Injector Circuit Low - Cylinder #7
P0280 Injector Circuit High - Cylinder #7
P0281 Cylinder #7 Balance Fault
P0282 Injector Circuit Low - Cylinder #8
P0283 Injector Circuit High - Cylinder #8
P0284 Cylinder #8 Balance Fault
P0285 Injector Circuit Low - Cylinder #9
P0286 Injector Circuit High - Cylinder #9
P0287 Cylinder #9 Balance Fault
P0288 Injector Circuit Low - Cylinder #10
P0289 Injector Circuit High - Cylinder #10
P0290 Cylinder #10 Balance Fault
P0291 Injector Circuit Low - Cylinder #11
P0292 Injector Circuit High - Cylinder #11
P0293 Cylinder #11 Balance Fault
P0294 Injector Circuit Low - Cylinder #12
P0295 Injector Circuit High - Cylinder #12
P0296 Cylinder #12 Balance Fault
P0300 Random Misfire Detected
P0301 Cylinder #1 Misfire Detected
P0302 Cylinder #2 Misfire Detected
P0303 Cylinder #3 Misfire Detected
P0304 Cylinder #4 Misfire Detected
P0305 Cylinder #5 Misfire Detected
P0306 Cylinder #6 Misfire Detected
P0307 Cylinder #7 Misfire Detected
P0308 Cylinder #8 Misfire Detected
P0309 Cylinder #9 Misfire Detected
P0310 Cylinder #10 Misfire Detected
P0311 Cylinder #11 Misfire Detected
P0312 Cylinder #12 Misfire Detected
P0320 Ignition Engine Speed Input Circuit Malfunction
P0321 Ignition Engine Speed Input Circuit Range/Performance
P0322 Ignition Engine Speed Input Circuit No Signal
P0323 Ignition Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance
P0327 Knock Sensor 1 Circuit Low Input
P0328 Knock Sensor 1 Circuit High Input
P0329 Knock Sensor 1 Circuit Intermittent
P0330 Knock Sensor 2 Circuit Malfunction
P0331 Knock Sensor 2 Circuit Range/Performance
P0332 Knock Sensor 2 Circuit Low Input
P0333 Knock Sensor 2 Circuit High Input
P0334 Knock Sensor 2 Circuit Intermittent
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary / Secondary Circuit Malfunction
P0351 Ignition Coil Primary A / Secondary Circuit Malfunction
P0352 Ignition Coil Primary B / Secondary Circuit Malfunction
P0353 Ignition Coil Primary C / Secondary Circuit Malfunction
P0354 Ignition Coil Primary D / Secondary Circuit Malfunction
P0355 Ignition Coil Primary E / Secondary Circuit Malfunction
P0356 Ignition Coil Primary F / Secondary Circuit Malfunction
P0357 Ignition Coil Primary G / Secondary Circuit Malfunction
P0358 Ignition Coil Primary H / Secondary Circuit Malfunction
P0359 Ignition Coil Primary I / Secondary Circuit Malfunction
P0360 Ignition Coil Primary J / Secondary Circuit Malfunction
P0361 Ignition Coil Primary K / Secondary Circuit Malfunction
P0362 Ignition Coil Primary L / Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug Circuit A Malfunction
P0381 Glow Plug Indicator Circuit Malfunction
P0382 Glow Plug Circuit B Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 EGR Flow Malfunction
P0401 EGR Flow Insufficient Detected
P0402 EGR Flow Excessive Detected
P0403 EGR Circuit Malfunction
P0404 EGR Circuit Range/Performance
P0405 EGR Sensor A Circuit Low Input
P0406 EGR Sensor A Circuit High Input
P0407 EGR Sensor B Circuit Low Input
P0408 EGR Sensor B Circuit High Input
P0410 SAI System Malfunction
P0411 SAI System Incorrect Upstream Flow Detected
P0412 SAI System Switching Valve A Circuit Malfunction
P0413 SAI System Switching Valve A Circuit Open
P0414 SAI System Switching Valve A Circuit Shorted
P0415 SAI System Switching Valve B Circuit Malfunction
P0416 SAI System Switching Valve B Circuit Open
P0417 SAI System Switching Valve B Circuit Shorted
P0418 SAI System Relay A Circuit Malfunction
P0419 SAI System Relay B Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected
P0443 Evap Emission Control System Purge Control Circuit Malf.
P0444 Evap Emission Control Sys Purge Control Valve Circuit Open
P0445 Evap Emission Control Sys Purge Control Valve Circuit Short
P0446 Evap Emission Control System Vent Malfunction
P0447 Evap Emission Control System Vent Circuit Open
P0448 Evap Emission Control System Vent Circuit Shorted
P0449 Evap Emission Control System Vent Circuit Intermittent
P0450 Evap Emission Control System Pressure Sensor Malfunction
P0451 Evap Emission Control System Pressure Sensor Performance
P0452 Evap Emission Control System Pressure Sensor Low Input
P0453 Evap Emission Control System Pressure Sensor High Input
P0454 Evap Emission Control System Pressure Sensor Intermittent
P0455 Evap Emission Control System Leak Detected (Gross Leak/No Flow)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Circuit Malfunction
P0471 Exhaust Pressure Sensor Circuit Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent
P0505 Idle Air Control System Malfunction
P0506 Idle Air Control System RPM Lower Than Expected
P0507 Idle Air Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Input
P0523 Engine Oil Pressure Sensor/Switch Circuit High Input
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 A/C Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise ON Signal Malfunction
P0566 Cruise OFF Signal Malfunction
P0567 Cruise RESUME Signal Malfunction
P0568 Cruise SET Signal Malfunction
P0569 Cruise COAST Signal Malfunction
P0570 Cruise ACCEL Signal Malfunction
P0571 Cruise Brake Switch Circuit Malfunction
P0572 Cruise Brake Switch Circuit Low
P0573 Cruise Brake Switch Circuit High
P0600 Serial Communications Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Powertrain Control Module KAM Test Error
P0604 Powertrain Control Module RAM Test Error
P0605 Powertrain Control Module ROM Test Error
P0606 PCM Processor Fault
P0608 PCM VSS Output A Malfunction
P0609 PCM VSS Output B Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 MIL Control Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Brake Switch Input Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit Malfunction
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Perf
P0712 Transmission Fluid Temp Sensor Circuit Low Input
P0713 Transmission Fluid Temp Sensor Circuit High Input
P0714 Transmission Fluid Temp Sensor Circuit Intermittent
P0715 Turbine Speed Sensor Circuit Malfunction
P0716 Turbine Speed Sensor Circuit Range/Performance
P0717 Turbine Speed Sensor Circuit No Signal
P0718 Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Shaft Speed Sensor Circuit Malfunction
P0721 Output Shaft Speed Sensor No Performance
P0722 Output Shaft Speed Sensor No Signal
P0723 Output Shaft Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed Input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch System Performance Or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch System Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid A Malfunction
P0746 Pressure Control Solenoid A Performance or Stuck Off
P0747 Pressure Control Solenoid A Stuck On
P0748 Pressure Control Solenoid A Electrical
P0749 Pressure Control Solenoid A Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0775 Pressure Control Solenoid B Malfunction
P0776 Pressure Control Solenoid B Performance
P0777 Pressure Control Solenoid B Stuck On
P0778 Pressure Control Solenoid B Electrical
P0779 Pressure Control Solenoid B Intermittent
P0780 Shift Malfunction
P0781 1 - 2 Shift Error
P0782 2 - 3 Shift Error
P0783 3 - 4 Shift Error
P0784 4 - 5 Shift Error
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Mode Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1 - 4 Upshift (Skip Shift) Solenoid Circuit Malfunction
P0804 1 - 4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1000 Check of all OBDII Systems Not Complete
P1001 KOER Not Able To Complete. KOER Aborted.
P1100 MAF Sensor Intermittent
P1101 MAF Sensor Out Of Self Test Range
P1102 MAF Sensor In Range But Lower Than Expected
P1103 MAF Sensor In Range But Higher Than Expected
P1104 MAF Ground Malfunction
P1105 Dual Alternator Upper Fault
P1106 Dual Alternator Lower Fault
P1107 Dual Alternator Lower Circuit Malfunction
P1108 Dual Alternator Battery Lamp Circuit Malfunction
P1109 IAT - B Sensor Intermittent
P1110 IAT Sensor (D/C) Open/Short
P1111 System Pass
P1112 IAT Sensor Intermittent
P1113 IAT Sensor (L/C) Open/Short
P1114 IAT - B Circuit Low Input
P1115 IAT - B Circuit High Input
P1116 ECT Sensor Out Of Self Test Range
P1117 ECT Sensor Intermittent
P1118 Manifold Absolute Temperature Circuit Low Input
P1119 Manifold Absolute Temperature Circuit High Input
P1120 TP Sensor Out Of Range Low (Ratch Too Low)
P1121 TP Sensor Inconsistent With MAF Sensor
P1122 TP In Range But Lower Than Expected
P1123 TP In Range But Higher Than Expected
P1124 TP Sensor Out Of Self Test Range
P1125 TP Sensor Intermittent
P1126 TP (Narrow Range) Sensor Circuit Malfunction
P1127 Exhaust Not Warm, Downstream O2 Sensor Not Tester
P1128 Upstream Heated O2 Sensors Swapped
P1129 Downstream Heated O2 Sensors Swapped
P1130 Lack Of HO2S11 Switch - Adaptive Fuel At Limit
P1131 Lack Of HO2S11 Switch - Sensor Indicates Lean
P1132 Lack Of HO2S11 Switch - Sensor Indicates Rich
P1133 Bank 1 Fuel Control Shifted Lean (FAOSC)
P1134 Bank 1 Fuel Control Shifted Rich (FAOSC)
P1135 Pedal Position Sensor A Circuit Intermittent
P1136 Control Box Fan Circuit Malfunction
P1137 Lack Of HO2S12 Switch - Sensor Indicates Lean
P1138 Lack Of HO2S12 Switch - Sensor Indicates Rich
P1139 Water In Fuel Indicator Circuit Malfunction
P1140 Water In Fuel Condition
P1141 Fuel Restriction Indicator Circuit Malfunction
P1142 Fuel Restriction Condition
P1143 Air Assist Control Valve Range/Performance
P1144 Air Assist Control Valve Circuit Malfunction
P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich
P1153 Bank 2 Fuel Control Shifted Lean (FAOSC)
P1154 Bank 2 Fuel Control Shifted Rich (FAOSC)
P1155 Alternative Fuel Controller Has Activated the MIL
P1156 Fuel Select Switch Malfunction
P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean
P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich
P1159 Fuel Stepper Motor Malfunction
P1167 Invalid Test, Operator Did Not Actuate Throttle
P1168 Fuel Rail Sensor In-Range Low Failure
P1169 Fuel Rail Sensor In-Range High Failure
P1170 ESO - Engine Shut Off Solenoid Fault
P1171 Rotor Sensor Fault
P1172 Rotor Control Fault
P1173 Rotor Calibration Fault
P1174 Cam Sensor Fault
P1175 Cam Control Fault
P1176 Cam Calibration Fault
P1177 Synchronisation Fault
P1178 Boltup Limits Fault
P1180 Fuel Delivery System Malfunction - Low
P1181 Fuel Delivery System Malfunction - High
P1182 Fuel Shut Off Solenoid Malfunction
P1183 Engine Oil Temperature Circuit Malfunction
P1184 Engine Oil Temperature Out Of Self Test Range
P1185 FTS High - Fuel Pump Temperature Sensor High
P1186 FTS Low - Fuel Pump Temperature Sensor Low
P1187 Variant Selection
P1188 Calibration Memory Fault
P1189 Pump Speed Signal Fault
P1190 Calibration Resistor Out Of Range
P1191 Key Line Voltage
P1192 V External
P1193 EGR Drive Overcurrent
P1194 ECU A/D Converter
P1195 SCP HBCC Failed To Initialize
P1196 Key Off Voltage High
P1197 Key Off Voltage Low
P1198 Pump Rotor Control Underfueling
P1199 Fuel Level Input Circuit Low
P1201 Injector Circuit Open / Shorted - Cylinder #1
P1202 Injector Circuit Open / Shorted - Cylinder #2
P1203 Injector Circuit Open / Shorted - Cylinder #3
P1204 Injector Circuit Open / Shorted - Cylinder #4
P1205 Injector Circuit Open / Shorted - Cylinder #5
P1206 Injector Circuit Open / Shorted - Cylinder #6
P1209 Injector Control Pressure System Fault
P1210 Injector Control Pressure Above Expected Level
P1211 Injector Control Pressure Sensor Above / Below Desired
P1212 Injector Control Pressure Not Detected During Crank
P1213 Start Injector Circuit Malfunction
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1218 CID High
P1219 CID Low
P1220 Series Throttle Control System Malfunction
P1221 Traction Control System Malfunction
P1222 Traction Control Output Circuit Malfunction
P1223 Pedal Demand Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1225 Needle Lift Sensor Malfunction
P1226 Control Sleeve Sensor Malfunction
P1227 Wastegate Failed Closed (Over Pressure)
P1228 Wastegate Failed Open (Under Pressure)
P1229 Intercooler Pump Driver Fault
P1230 Fuel Pump Low Speed Malfunction
P1231 Fuel Pump Secondary Circuit Low, High Speed
P1232 Fuel Pump Speed Primary Circuit Malfunction
P1233 Fuel Pump Driver Module Off Line
P1234 Fuel Pump Driver Module Off Line
P1235 Fuel Pump Control Out Of Range
P1236 Fuel Pump Control Out Of Range
P1237 Fuel Pump Secondary Circuit Malfunction
P1238 Fuel Pump Secondary Circuit Malfunction
P1239 Speed Fuel Pump Positive Feed Fault
P1240 Sensor Power Supply Malfunction
P1241 Sensor Power Supply Low Input
P1242 Sensor Power Supply High Input
P1243 Second Fuel Pump Faulty or Ground Fault
P1244 Alternator Load Input Failed High
P1245 Alternator Load Input Failed Low
P1246 Alternator Load Input Failed
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastegate Control Valve Performance
P1250 PRC Solenoid Circuit Malfunction
P1251 Air Mixture Solenoid Circuit Malfunction
P1252 Pedal Correlation PDS1 and LPDS High
P1253 Pedal Correlation PDS1 and LPDS Low
P1254 Pedal Correlation PDS2 and LPDS High
P1255 Pedal Correlation PDS2 and LPDS Low
P1256 Pedal Correlation PDS1 and HPDS
P1257 Pedal Correlation PDS2 and HPDS
P1258 Pedal Correlation PDS1 and PDS2
P1259 Immobilizer to PCM Signal Error
P1260 THEFT Detected, Vehicle Immobilzed
P1261 Cylinder #1 High To Low Side Short
P1262 Cylinder #2 High To Low Side Short
P1263 Cylinder #3 High To Low Side Short
P1264 Cylinder #4 High To Low Side Short
P1265 Cylinder #5 High To Low Side Short
P1266 Cylinder #6 High To Low Side Short
P1267 Cylinder #7 High To Low Side Short
P1268 Cylinder #8 High To Low Side Short
P1269 Immobilizer Code Not Programmed
P1270 Engine RPM Or Speed Limiter Reached
P1271 Cylinder #1 High To Low Side Open
P1272 Cylinder #2 High To Low Side Open
P1273 Cylinder #3 High To Low Side Open
P1274 Cylinder #4 High To Low Side Open
P1275 Cylinder #5 High To Low Side Open
P1276 Cylinder #6 High To Low Side Open
P1277 Cylinder #7 High To Low Side Open
P1278 Cylinder #8 High To Low Side Open
P1280 Injection Control Pressure Out Of Range Low
P1281 Injection Control Pressure Out Of Range High
P1282 Excessive Injection Control Pressure
P1283 IPR Circuit Failure
P1284 Aborted KOER - ICP Failure
P1285 Cylinder Head Overtemperature Sensed
P1286 Fuel Pulse In Range But Lower Than Expected
P1287 Fuel Pulse In Range But Higher Than Expected
P1288 Cylinder Head Temp Sensor Out Of Self Test Range
P1289 Cylinder Head Temp Sensor High Input
P1290 Cylinder Head Temp Sensor Low Input
P1291 Injector High Side Short To GND Or VBATT - Bank 1
P1292 Injector High Side Short To GND Or VBATT - Bank 2
P1293 Injector High Side Open - Bank 1
P1294 Injector High Side Open - Bank 2
P1295 Multi-faults - Bank 1 - With Low Side Shorts
P1296 Multi-faults - Bank 2 - With Low Side Shorts
P1297 Injector High Sides Shorted Together
P1298 IDM Failure
P1299 Cylinder Head Overtemperature Protection Active
P1300 Boost Calibration Fault
P1301 Boost Calibration High
P1302 Boost Calibration Low
P1303 EGR Calibration Fault
P1304 EGR Calibration High
P1305 EGR Calibration Low
P1306 Kickdown Relay Pull - In Circuit Fault
P1307 Kickdown Relay Hold Circuit Fault
P1308 A/C Clutch Circuit Fault
P1309 Misfire Monitor AICE Chip Fault
P1313 Misfire Rate Catalyst Damage Fault - Bank 1
P1314 Misfire Rate Catalyst Damage Fault - Bank 2
P1315 Persistent Misfire
P1316 Injector Circuit / IDM Codes Detected
P1317 Injector Circuit / IDM Codes Not Updated
P1336 Crank / Cam Sensor Range / Performance
P1340 Camshaft Position Sensor B Circuit Malfunction
P1341 Camshaft Position Sensor B Range / Performance
P1345 SGC (Cam Position) Sensor Circuit Malfunction
P1346 Fuel Level Sensor B Circuit Malfunction
P1347 Fuel Level Sensor B Range / Performance
P1348 Fuel Level Sensor B Circuit Low
P1349 Fuel Level Sensor B Circuit High
P1350 Fuel Level Sensor B Intermittent
P1351 IDM Input Circuit Malfunction
P1352 Ignition Coil A Primary Circuit Malfunction
P1353 Ignition Coil B Primary Circuit Malfunction
P1354 Ignition Coil C Primary Circuit Malfunction
P1355 Ignition Coil D Primary Circuit Malfunction
P1356 IDM Pulsewidth Indicates Engine Not Turning
P1357 IDM Pulsewidth Not Defined
P1358 IDM Signal Out Of Self Test Range (No CPUOK)
P1359 Spark Output Circuit Malfunction
P1360 Ignition Coil A Secondary Circuit Malfunction
P1361 Ignition Coil B Secondary Circuit Malfunction
P1362 Ignition Coil C Secondary Circuit Malfunction
P1363 Ignition Coil D Secondary Circuit Malfunction
P1364 Ignition Coil Primary Circuit Failure
P1365 Ignition Coil Secondary Circuit Failure
P1366 Ignition Spare
P1367 Ignition Spare
P1368 Ignition Spare
P1369 Engine Temperature Light Monitor Failure
P1370 Insufficient RMP Increase During Spark Test
P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
P1374 Ignition Coil - Cylinder 4 - Early Activation Fault
P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
P1380 Variable Cam Timing Solenoid A Malfunction
P1381 Variable Cam Timing Overadvanced (Bank #1)
P1382 Variable Cam Timing Solenoid #1 Circuit Malfunction
P1383 Variable Cam Timing Overretarded (Bank #1)
P1384 VVT Solenoid A Malfunction
P1385 Variable Cam Timing Solenoid B Malfunction
P1386 Variable Cam Timing Overadvanced (Bank #2)
P1387 Variable Cam Timing Solenoid #2 Circuit Malfunction
P1388 Variable Cam Timing Overretarded (Bank #2)
P1389 Glow Plug Circuit High Side Low Input
P1390 Octane Adjust Pin Out Of Self Test Range
P1391 Glow Plug Circuit Low Input (Bank #1)
P1392 Glow Plug Circuit High Input (Bank #1)
P1393 Glow Plug Circuit Low Input (Bank #2)
P1394 Glow Plug Circuit High Input (Bank #2)
P1395 Glow Plug Monitor Fault (Bank #1)
P1396 Glow Plug Monitor Fault (Bank #2)
P1397 System Voltage Out Of Self Test Range
P1398 VVT Solenoid B Circuit High Input
P1399 Glow Plug Circuit High Side, High Input
P14 Seat Position Hall Sensor Feedback Failure
P1400 DPFE Circuit Low Input
P1401 DPFE Circuit High Input
P1402 EGR Metering Orifice Restricted
P1403 DPFE Sensor Hoses Reversed
P1404 IAT - B Circuit Malfunction
P1405 DPFE Sensor Upstream Hose Off Or Plugged
P1406 DPFE Sensor Downstream Hose Off Or Plugged
P1407 EGR No Flow Detected
P1408 EGR Flow Out Of Self Test Range
P1409 EVR Control Circuit Malfunction
P1411 SAI System Incorrect Downstream Flow Detected
P1413 SAI System Monitor Circuit Low Input
P1414 SAI System Monitor Circuit High Input
P1415 Air Pump Circuit Malfunction
P1416 Port Air Circuit Malfunction
P1417 Port Air Relief Circuit Malfunction
P1418 Split Air #1 Circuit Malfunction
P1419 Split Air #2 Circuit Malfunction
P1420 Catalyst Temperature Sensor Failure
P1421 Catalyst Damage
P1422 EGI Temperature Sensor Failure
P1423 EGI Functionality Test Failed
P1424 EGI Glow Plug Primary Failure
P1425 EGI Glow Plug Secondary Failure
P1426 EGI Mini - MAF Failed Out Of Range
P1427 EGI Mini - MAF Failed Short Circuit
P1428 EGI Mini - MAF Failed Open Circuit
P1429 Electric Air Pump Primary Failure
P1430 Electric Air Pump Secondary Failure
P1433 A/C Refrigerant Temperature Circuit Low
P1434 A/C Refrigerant Temperature Circuit High
P1435 A/C Refrigerant Temperature Circuit Range/Performance
P1436 A/C Evaporator Air Temperature Circuit Low
P1437 A/C Evaporator Air Temperature Circuit High
P1438 A/C Evaporator Air Temperature Circuit Range/Performance
P1439 Floor Temperature Switch Circuit Malfunction
P1440 Purge Valve Stuck Open
P1441 ELC System Fault
P1442 Evaporative Emission Control System Leak Detected
P1443 Evaporative Emission Control System Control Valve Malf.
P1444 Purge Flow Sensor Circuit Low Input
P1445 Purge Flow Sensor Circuit High Input
P1446 Evaporative Vac Solenoid Circuit Malfunction
P1447 ELC System Closure Valve Flow Fault
P1448 ELC System 2 Fault
P1449 Evaporative Check Solenoid Circuit Malfunction
P1450 Unable To Bleed Up Fuel Tank Vacuum
P1451 Evap. Emission Control Sys. Vent Control Valve Circuit Malf.
P1452 Unable To Bleed - Up Vacuum in Tank
P1453 Fuel Tank Pressure Relief Valve Malfunction
P1454 Evaporative System Vacuum Test Malfunction
P1455 Evap. Emission Control Sys. Leak Detected (Gross Leak/No Flow)
P1456 Fuel Tank Temperature Sensor Circuit Malfunction
P1457 Unable To Pull Vacuum In Tank
P1460 WOT A/C Cutout Circuit Malfunction
P1461 A/C Pressure Sensor Circuit High Input
P1462 A/C Pressure Sensor Circuit Low Input
P1463 A/C Pressure Sensor Insufficient Pressure Change
P1464 A/C Demand Out of Self Test Range
P1465 A/C Relay Circuit Malfunction
P1466 A/C Refrigerant Temperature Sensor/Circuit Malfunction
P1467 A/C Compressor Temperature Sensor Malfunction
P1468 SSPOD Open Circuit or Closed Circuit Fault
P1469 Low A/C Cycling Period
P1470 A/C Cycling Period Too Short
P1471 Electrodrive Fan 1 Operational Failure (Driver Side)
P1472 Electrodrive Fan 2 Operational Failure (Passenger Side)
P1473 Fan Secondary High With Fan(s) Off
P1474 Low Fan Control Primary Circuit Malfunction
P1475 Fan Relay (Low) Circuit Malfunction
P1476 Fan Relay (High) Circuit Malfunction
P1477 Additional Fan Relay Circuit Malfunction
P1478 Cooling Fan Driver Fault
P1479 High Fan Control Primary Circuit Malfunction
P1480 Fan Secondary Low with Low Fan On
P1481 Fan Secondary Low With High Fan On
P1482 SCP
P1483 Power To Fan Circuit Overcurrent
P1484 Open Power To Ground VCRM
P1485 EGRV Circuit Malfunction
P1486 EGRA Circuit Malfunction
P1487 EGRCHK Solenoid Circuit Malfunction
P1490 Secondary Air Relief Solenoid Circuit Malfunction
P1491 Secondary Switch Solenoid Circuit Malfunction
P1492 APLSOL Solenoid Circuit Malfunction
P1493 RCNT Solenoid Circuit Malfunction
P1494 SPCUT Solenoid Circuit Malfunction
P1495 TCSPL Solenoid Circuit Malfunction
P1500 Vehicle Speed Sensor Intermittent
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Intermittent Malfunction
P1503 Auxillary Speed Sensor Fault
P1504 Idle Air Control Circuit Malfunction
P1505 Idle Air Control System At Adaptive Clip
P1506 Idle Air Control Overspeed Error
P1507 Idle Air Control Underspeed Error
P1508 Idle Control System Circuit Open
P1509 Idle Control System Circuit Shorted
P1510 Idle Signal Circuit Malfunction
P1511 Idle Switch (Electric Control Throttle) Circuit Malfunction
P1512 Intake Manifold Runner Control (Bank 1) Stuck Closed
P1513 Intake Manifold Runner Control (Bank 2) Stuck Closed
P1514 High Load Neutral/Drive Fault
P1515 Electric Current Circuit Malfunction
P1516 IMRC Input Error (Bank 1)
P1517 IMRC Input Error (Bank 2)
P1518 Intake Manifold Runner Control (Stuck Open)
P1519 Intake Manifold Runner Control (Stuck Closed)
P1520 Intake Manifold Runner Control Circuit Malfunction
P1521 Variable Intake Solenoid #1 Circuit Malfunction
P1522 Variable Intake Solenoid #2 Circuit Malfunction
P1523 IVC Solenoid Circuit Malfunction
P1524 Variable Intake Solenoid System
P1525 Air Bypass Valve System
P1526 Air Bypass System
P1527 Accelerate Warmup Solenoid Circuit Malfunction
P1528 Subsidiary Throttle Valve Solenoid Circuit Malfunction
P1529 SCAIR Solenoid Circuit Malfunction
P1530 A/C Clutch Circuit Malfunction
P1531 Invalid Test - Accelerator Pedal Movement
P1532 IMCC Circuit Malfunction, Bank B
P1533 AAI Circuit Malfunction
P1534 Inertia Switch Activated
P1535 Blower Fan Speed Circuit Range/Performance
P1536 Parking Brake Switch Circuit Failure
P1537 Intake Manifold Runner Control (Bank 1) Stuck Open
P1538 Intake Manifold Runner Control (Bank 2) Stuck Open
P1539 Power To A/C Clutch Circuit Overcurrent
P1540 Air Bypass Valve Circuit Malfunction
P1549 IMCC Circuit Malfunction, Bank B
P1550 PSPS Out Of Self Test Range
P1565 Speed Control Command Switch Out of Range High
P1566 Speed Control Command Switch Out of Range Low
P1567 Speed Control Output Circuit Continuity
P1568 Speed Control Unable to Hold Speed
P1571 Brake Switch Malfunction
P1572 Brake Pedal Switch Circuit Malfunction
P1573 Throttle Position Not Available
P1574 Throttle Position Sensor Disagreement btwn Sensors
P1575 Pedal Position Out of Self Test Range
P1576 Pedal Position Not Available
P1577 Pedal Position Sensor Disagreement btwn Sensors
P1578 ETC Power Less Than Demand
P1579 ETC In Power Limiting Mode
P1580 Electronic Throttle Monitor PCM Override
P1581 Electronic Throttle Monitor Malfunction
P1582 Electronic Throttle Monitor Data Available
P1583 Electronic Throttle Monitor Cruise Disable
P1584 TCU Detected IPE Circuit Malfunction
P1585 Throttle Control Unit Malfunction
P1586 Throttle Control Unit Throttle Position Malfunction
P1587 Throttle Control Unit Modulated Command Malfunction
P1588 Throttle Control Unit Detected Loss of Return Spring
P1589 TCU Unable To Control Desired Throttle Angle
P1600 Loss of KAM Power; Open Circuit
P1601 ECM/TCM Serial Communication Error
P1602 Immobilizer/ECM Communication Error
P1603 EEPROM Malfunction
P1604 Code Word Unregestered
P1605 Keep Alive Memory Test Failure
P1606 ECM Control Relay O/P Circuit Malfunction
P1607 MIL O/P Circuit Malfunction
P1608 Internal ECM Malfunction
P1609 Diagnostic Lamp Driver Fault
P1610 SBDS Interactive Codes
P1611 SBDS Interactive Codes
P1612 SBDS Interactive Codes
P1613 SBDS Interactive Codes
P1614 SBDS Interactive Codes
P1615 SBDS Interactive Codes
P1616 SBDS Interactive Codes
P1617 SBDS Interactive Codes
P1618 SBDS Interactive Codes
P1619 SBDS Interactive Codes
P1620 SBDS Interactive Codes
P1621 Immobilizer Code Words Do Not Match
P1622 Immobilizer ID Does Not Match
P1623 Immobilizer Code Word/ID Number Write Failure
P1624 Anti Theft System
P1625 B+ Supply To VCRM Fan Circuit Malfunction
P1626 B+ Supply To VCRM A/C Circuit Malfunction
P1627 Module Supply Voltage Out Of Range
P1628 Module Ignition Supply Input Malfunction
P1629 Internal Voltage Regulator Malfunction
P1630 Internal Vref Malfunction
P1631 Main Relay Malfunction (Power Hold)
P1632 Smart Alternator Faults Sensor/Circuit Malfunction
P1633 KAM Voltage Too Low
P1634 Data Output Link Circuit Failure
P1635 Tire / Axle Ratio Out of Acceptable Range
P1636 Inductive Signature Chip Communication Error
P1637 Can Link ECM/ABSCM Circuit / Network Malfunction
P1638 Can Link ECM/INSTM Circuit / Network Malfunction
P1639 Vehicle ID Block Corrupted or Not Programmed
P1640 Powertrain DTCs Available in Another Module
P1641 Fuel Pump Primary Circuit Failure
P1642 Fuel Pump Monitor Circuit High Input
P1643 Fuel Pump Monitor Circuit Low Input
P1644 Fuel Pump Speed Control Circuit Malfunction
P1645 Fuel Pump Resistor Switch Circuit Malfunction
P1650 PSP Switch Out of Self Test Range
P1651 PSP Switch Input Malfunction
P1652 IAC Monitor Disabled by PSP Switch Failed On
P1653 Power Steering Output Circuit Malfunction
P1654 Recirculation Override Circuit Malfunction
P1655 Starter Disable Circuit Malfunction
P1660 Output Circuit Check Signal High
P1661 Output Circuit Check Signal Low
P1662 IDM_EN Circuit Failure
P1663 Fuel Demand Command Signal Circuit Malfunction
P1667 CI Circuit Malfunction
P1668 PCM - IDM Communications Error
P1670 Electronic Feedback Signal Not Detected
P1680 Metering Oil Pump Malfunction
P1681 Metering Oil Pump Malfunction
P1682 Metering Oil Pump Malfunction
P1683 Metering Oil Pump Temperature Sensor Circuit Malfunction
P1684 Metering Oil Pump Position Sensor Circuit Malfunction
P1685 Metering Oil Pump Stepping Motor Circuit Malfunction
P1686 Metering Oil Pump Stepping Motor Circuit Malfunction
P1687 Metering Oil Pump Stepping Motor Circuit Malfunction
P1688 Metering Oil Pump Stepping Motor Circuit Malfunction
P1689 Oil Pressure Control Solenoid Circuit Malfunction
P1690 Wastegate Solenoid Circuit Malfunction
P1691 Turbo Pressure Control Solenoid Circuit Malfunction
P1692 Turbo Control Solenoid Circuit Malfunction
P1693 Turbo Charge Control Circuit Malfunction
P1694 Turbo Charge Relief Circuit Malfunction
P1700 Transmission Indeterminate Failure (Failed to Neutral)
P1701 Reverse Engagement Error
P1702 TRS Circuit Intermittent Malfunction
P1703 Brake Switch Out Of Self Test Range
P1704 Digital TRS Failed to Transition States in KOEO / KOER
P1705 Not in P or N During KOEO / KOER
P1706 High Vehicle Speed Observed in Park
P1707 Transfer Case Neutral Indicator Hard Fault Present
P1708 Clutch Switch Circuit Malfunction
P1709 PNP Switch Out Of Self Test Range
P1711 TFT Sensor Out Of Self Test Range
P1712 Trans Torque Reduction Request Signal Malfunction
P1713 TFT Sensor In Range Failure Low Value
P1714 SSA Inductive Signature Malfunction
P1715 SSB Inductive Signature Malfunction
P1716 SSC Inductive Signature Malfunction
P1717 SSD Inductive Signature Malfunction
P1718 TFT Sensor In Range Failure High
P1720 Vehicle Speed (Meter) Circuit Malfunction
P1721 Gear 1 Incorrect Ratio
P1722 Gear 2 Incorrect Ratio
P1723 Gear 3 incorrect Ratio
P1724 Gear 4 Incorrect Ratio
P1725 Insufficient Engine Speed Increase During Self Test
P1726 Insufficient Engine Speed Decrease During Self Test
P1727 Coast Clutch Solenoid Inductive Signature Malfunction
P1728 Transmission Slip Error
P1729 4x4 Low Switch Error
P1730 Gear Control Malfunction 2,3,5
P1731 1-2 Shift Malfunction
P1732 2-3 Shift Malfunction
P1733 3-4 Shift Malfunction
P1734 Gear Control Malfunction
P1735 First Gear Switch Circuit Malfunction
P1736 Second Gear Switch Circuit Malfunction
P1737 Lockup Solenoid System
P1738 Shift Time Error
P1739 Slip Solenoid System
P1740 Torque Converter Clutch Inductive Signature Malfunction
P1741 Torque Converter Clutch Control Error
P1742 Torque Converter Clutch Solenoid Failed On
P1743 Torque Converter Clutch Solenoid Failied On
P1744 Torque Converter Clutch System Performance
P1745 Line Pressure Solenoid System
P1746 Pressure Control Solenoid "A" Open Circuit
P1747 Pressure Control Solenoid "A" Short Circuit
P1748 EPC Malfunction
P1749 Pressure Control Solenoid Failed Low
P1751 Shift Solenoid A Performance
P1754 Coast Clutch Solenoid Circuit Malfunction
P1755 Intermediate Speed Sensor (ISS) Malfunction
P1756 Shift Solenoid B Performance
P1760 Pressure Control Solenoid "A" Short Circuit
P1761 Shift Solenoid C Performance
P1762 Overdrive Band Failed Off
P1765 Timing Solenoid Circuit Malfunction
P1767 Torque Converter Clutch Circuit Malfunction
P1768 Performance / Normal / Winter Mode Input Malfunction
P1769 AG4 Transmission Torque Modulation Fault
P1770 Clutch Solenoid Circuit Malfunction
P1775 Transmission System MIL Fault
P1776 Ignition Retard Request Duration Fault
P1777 Ignition Retard Request Circuit Fault
P1778 Transmission Reverse I/P Circuit Malfunction
P1779 TCIL Circuit Malfunction
P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range
P1781 4X4 Switch Out of Self Test Range
P1782 P/ES Circuit Out Of Self Test Range
P1783 Transmission Overtemperature Condition
P1784 Transmission Mechanical Failure - First And Reverse
P1785 Transmission Mechanical Failure - First And Second
P1786 3-2 Downshift Error
P1787 2-1 Downshift Error
P1788 Pressure Control Solenoid "B" Open Circuit
P1789 Pressure Control Solenoid "B" Short Circuit
P1790 TP (Mechanical) Circuit Malfunction
P1791 TP (Electric) Circuit Malfunction
P1792 Barometer Pressure Circuit Malfunction
P1793 Intake Air Volume Circuit Malfunction
P1794 Battery Voltage Circuit Malfunction
P1795 Idle Switch Circuit Malfunction
P1796 Kick Down Switch Circuit Malfunction
P1797 Neutral Switch Circuit Malfunction
P1798 Coolant Temperature Circuit Malfunction
P1799 Hold Switch Circuit Malfunction
P1800 Transmission Clutch Interlock Safety Switch Circuit Failure
P1801 Transmission Clutch Interlock Safety Switch Open Circuit
P1802 Transmission Clutch Interlock Safety Switch Short Circuit To Battery
P1803 Transmission Clutch Interlock Safety Switch Short Circuit To Ground
P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
P1805 Transmission 4-Wheel Drive High Indicator Open Circuit
P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
P1807 Transmission 4-Wheel Drive High Indicator Short Circuit To Ground
P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure
P1809 Transmission 4-Wheel Drive Low Indicator Open Circuit
P1810 Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
P1811 Transmission 4-Wheel Drive Low Indicator Short Circuit To Ground
P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure
P1813 Transmission 4-Wheel Drive Mode Select Open Circuit
P1814 Transmission 4-Wheel Drive Mode Select Short Circuit To Battery
P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
P1816 Transmission Neutral Safety Switch Circuit Failure
P1817 Transmission Neutral Safety Switch Open Circuit
P1818 Transmission Neutral Safety Switch Short Circuit To Battery
P1819 Transmission Neutral Safety Switch Short Circuit To Ground
P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
P1821 Transmission Transfer Case Clockwise Shift Relay Coil Open Circuit
P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
P1823 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground
P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure
P1825 Transmission 4-Wheel Drive Clutch Relay Open Circuit
P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
P1827 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Ground
P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
P1829 Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
P1831 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground
P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
P1833 Transmission Transfer Case Differential Lock-Up Solenoid Open Circuit
P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
P1835 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground
P1836 Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure
P1837 Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure
P1838 Transmission Transfer Case Shift Motor Circuit Failure
P1839 Transmission Transfer Case Shift Motor Open Circuit
P1840 Transmission Transfer Case Shift Motor Short Circuit To Battery
P1841 Transmission Transfer Case Shift Motor Short Circuit To Ground
P1842 Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure
P1843 Transmission Transfer Case Differential Lock-Up Feedback Switch Open Circuit
P1844 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery
P1845 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground
P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure
P1847 Transmission Transfer Case Contact Plate 'A' Open Circuit
P1848 Transmission Transfer Case Contact Plate 'A' Short Circuit To Battery
P1849 Transmission Transfer Case Contact Plate 'A' Short Circuit To Ground
P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure
P1851 Transmission Transfer Case Contact Plate 'B' Open Circuit
P1852 Transmission Transfer Case Contact Plate 'B' Short Circuit To Battery
P1853 Transmission Transfer Case Contact Plate 'B' Short Circuit To Ground
P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure
P1855 Transmission Transfer Case Contact Plate 'C' Open Circuit
P1856 Transmission Transfer Case Contact Plate 'C' Short Circuit To Battery
P1857 Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground
P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure
P1859 Transmission Transfer Case Contact Plate 'D' Open Circuit
P1860 Transmission Transfer Case Contact Plate 'D' Short Circuit To Battery
P1861 Transmission Transfer Case Contact Plate 'D' Short Circuit To Ground
P1862 Transmission Transfer Case Contact Plate Power Circuit Failure
P1863 Transmission Transfer Case Contact Plate Power Open Circuit
P1864 Transmission Transfer Case Contact Plate Power Short To Battery
P1865 Transmission Transfer Case Contact Plate Power Short To Ground
P1866 Transmission Transfer Case System Concern - Servicing Required
P1867 Transmission Transfer Case Contact Plate General Circuit Failure
P1868 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Failure
P1869 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Short To Battery
P1870 Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure
P1871 Transmission Mechanical Transfer Case 4x4 Switch Circuit Short To Battery
P1872 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Failure
P1873 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Short To Battery
P1874 Transmission Automatic Hall Effect Sensor Power Circuit Failure
P1875 Transmission Automatic Hall Effect Sensor Power Circuit Short To Battery
P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure
P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
P1878 Transmission Transfer Case Disengaged Solenoid Circuit Failure
P1879 Transmission Transfer Case Disengaged Solenoid Open Circuit
P1880 Transmission Transfer Case Disengaged Solenoid Short to Battery
P1881 Engine Coolant Level Switch Circuit Failure, GEM
P1882 Engine Coolant Level Switch Circuit Short to Ground
P1883 Engine Coolant Level Switch Circuit Failure, GEM
P1884 Engine Coolant Level Lamp Circuit Short to Ground
P1885 Transmission Transfer Case Disengaged Solenoid Short to Ground
P1886 4X4 Initialization Failure
P1890 Transmission 4WD Mode Select Return Input Circuit Failure
P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit
P1900 OSS Circuit Intermittent Malfunction
P1901 TSS Circuit Intermittent Malfunction
P1902 Pressure Control Solenoid "B" Intermittent Short
P1903 Pressure Control Solenoid "C" Short Circuit
P1904 Pressure Control Solenoid "C" Open Circuit
P1905 Pressure Control Solenoid "C" Intermittent Short
P1906 Kickdown Pull Relay Open or Short Circuit to Ground
P1907 Kickdown Hold Relay Open or Short Circuit to Ground
P1908 Transmission Pressure Circuit Solenoid Open or Short to Ground
P1909 Trans. Temp. Sensor Circuit Open or Shorted to Pwr. or Gnd.
P1910 VFS A Pressure Output Failed Low
P1911 VFS B Pressure Output Failed Low
P1912 VFS C Pressure Output Failed Low
P1913 Pressure Switch A Circuit Malfunction
P1914 Manually Shifted Automatic (MSA) Sw. Circuit Malf.
P1915 Reverse Switch Circuit Malfunction
P1916 High Clutch Drum Speed Sensor Malfunction
P1917 High Clutch Drum Speed Sensor Intermittent
P1918 Transmission Range Display Circuit Malfunction
C0869 Air Suspension Auxiliary Inflator Indicator Lamp Circuit Failure
C1091 Speed Wheel Sensor All Coherency Failure
C1095 ABS Hydraulic Pump Motor Circuit Failure
C1096 ABS Hydraulic Pump Motor Circuit Open
C1097 ABS Hydraulic Pump Motor Circuit Short To Ground
C1098 ABS Hydraulic Pump Motor Circuit Short To Battery
C1100 ABS Pump Switch Circuit Failure
C1101 ABS Hydraulic Valve Circuit Failure
C1102 ABS Acceleration Switch Circuit Failure
C1103 ABS Hydraulic Brake Switch Circuit Failure
C1104 Traction Control Active Lamp - Circuit Short to Battery
C1105 Traction Control Disable Lamp - Circuit Short to Battery
C1106 Traction Control Disable Switch Circuit Short to Battery
C1107 ABS Function Enabled Input Circuit Failure
C1109 Speed Control Actuator Assembly Cable Release Failure
C1110 ABS Power Relay Coil Circuit Failure
C1111 ABS Power Relay Coil Open Circuit
C1112 ABS Power Relay Coil Short Circuit To Ground
C1113 ABS Power Relay Coil Short Circuit To Battery
C1114 ABS Power Relay Output Short Circuit To Ground
C1115 ABS Power Relay Output Short Circuit To Battery
C1116 Starter Motor Circuit Failure
C1117 RPM Input Circuit Failure
C1123 Vehicle Speed Sensor Input Short to Battery
C1124 Input shaft speed signal missing/faulted
C1125 Brake Fluid Level Sensor Input Circuit Failure
C1126 Cruise Control Command Switch Assembly Circuit Failure
C1127 Cruise Control Deactivator Brake Switch Circuit Failure
C1132 Clutch position ckt short to ground
C1133 Clutch position ckt short to battery
C1134 Gear Shift position short to ground
C1135 Gear Shift position short to battery
C1136 Gear Select position short to ground
C1137 ECU is Defective
C1138 Gear Select position short to Battery
C1139 Wheel Speed Sensor Center Tone Ring Missing Tooth Fault
C1140 Hydraulic Base Brake Failure
C1141 Wheel Speed Sensor LF Tone Ring Tooth Missing Fault
C1142 Wheel Speed Sensor RF Tone Ring Tooth Missing Fault
C1143 Wheel Speed Sensor LR Tone Ring Tooth Missing Fault
C1144 Wheel Speed Sensor RR Tone Ring Tooth Missing Fault
C1145 Speed Wheel Sensor RF Input Circuit Failure
C1146 Speed Wheel Sensor RF Circuit Open
C1148 Speed Wheel Sensor RF Coherency Fault
C1149 Hydraulic Fluid Pressure/ Flow Circuit Failure
C1150 Two Speed Rear Axle Input Switch Circuit Short to Vbatt
C1155 Speed Wheel Sensor LF Input Circuit Failure
C1156 Speed Wheel Sensor LF Circuit Open
C1157 Park Brake Actuator Assembly Switch Applied Circuit Failure
C1158 Speed Wheel Sensor LF Coherency Fault
C1159 Hydraulic Fluid Pressure/ Flow Circuit Short to Gnd
C1161 Air Pressure Low Circuit Short to Gnd
C1162 Park Brake Switch # 2 Released Circuit Failure
C1163 Park Brake Switch # 2 Applied Circuit Short to Gnd
C1164 Park Brake Actuator Assembly Switch Circuit Failure
C1165 Speed Wheel Sensor RR Input Circuit Failure
C1166 Speed Wheel Sensor RR Input Open Circuit
C1167 Park Brake Actuator Assembly Switch Released Circuit Short to Gnd
C1168 Speed Wheel Sensor RR Coherency Fault
C1169 ABS Fluid Dumping Exceeds Maximum Timing
C1170 PRNDL Switch Circuit Failure
C1172 Park Brake Switch # 1 Applied Circuit Failure
C1173 Park Brake Switch # 1 Released Circuit Short to Gnd
C1174 Park Brake Switch # 2 Applied Circuit Failure
C1175 Speed Wheel Sensor LR Input Circuit Failure
C1176 Speed Wheel Sensor LR Circuit Open
C1177 Park Brake Actuator Assembly Switch Released Circuit Failure
C1178 Speed Wheel Sensor LR Coherency Fault
C1179 Speed Control Actuator Assembly Cable Slack Failure
C1180 Park Brake Valve Solenoid #1 Sense Input Circuit Failure
C1181 Park Brake Valve Solenoid #1 Sense Input Circuit Short to Gound
C1182 Park Lamp Flash Relay Circuit Failure
C1183 Park Lamp Flash Relay Circuit Short to Battery
C1184 ABS System Is Not Operational
C1185 ABS Power Relay Output Circuit Failure
C1186 ABS Power Relay Output Open Circuit
C1187 Brake Fluid Level Sensor Input Open Circuit
C1188 Brake Fluid Level Sensor Input Short Circuit To Battery
C1189 Brake Fluid Level Sensor Input Short Circuit To Ground
C1190 Speed Wheel Sensor LF Input Short Circuit To Battery
C1191 Speed Wheel Sensor LF Input Short Circuit To Ground
C1192 Speed Wheel Sensor RF Input Short Circuit To Battery
C1193 Speed Wheel Sensor RF Input Short Circuit To Ground
C1194 ABS Outlet Valve Coil LF Circuit Failure
C1195 ABS Outlet Valve Coil LF Circuit Open
C1196 ABS Outlet Valve Coil LF Circuit Short To Battery
C1197 ABS Outlet Valve Coil LF Circuit Short To Ground
C1198 ABS Inlet Valve Coil LF Circuit Failure
C1199 ABS Inlet Valve Coil LF Circuit Open
C1200 ABS Inlet Valve Coil LF Circuit Short To Battery
C1201 ABS Inlet Valve Coil LF Circuit Short To Ground
C1202 ABS Outlet Valve Coil Rear Circuit Failure
C1203 ABS Outlet Valve Coil Rear Circuit Open
C1204 ABS Outlet Valve Coil Rear Circuit Short To Battery
C1205 ABS Outlet Valve Coil Rear Circuit Short To Ground
C1206 ABS Inlet Valve Coil Rear Circuit Failure
C1207 ABS Inlet Valve Coil Rear Circuit Open
C1208 ABS Inlet Valve Coil Rear Circuit Short To Battery
C1209 ABS Inlet Valve Coil Rear Circuit Short To Ground
C1210 ABS Outlet Valve Coil RF Circuit Failure
C1211 ABS Outlet Valve Coil RF Circuit Open
C1212 ABS Outlet Valve Coil RF Circuit Short To Battery
C1213 ABS Outlet Valve Coil RF Circuit Short To Ground
C1214 ABS Inlet Valve Coil RF Circuit Failure
C1215 ABS Inlet Valve Coil RF Circuit Open
C1216 ABS Inlet Valve Coil RF Circuit Short To Battery
C1217 ABS Inlet Valve Coil RF Circuit Short To Ground
C1218 Lamp ABS Warning Output Circuit Failure
C1219 Lamp ABS Warning Output Circuit Open
C1220 Lamp ABS Warning Output Circuit Short To Battery
C1221 Lamp ABS Warning Output Circuit Short To Ground
C1222 Speed Wheel Mismatch
C1223 Lamp Brake Warning Output Circuit Failure
C1224 Lamp Brake Warning Output Ci
1999 grand marquis
11-07-2009, 10:15 PM
Pulled a error code P0136 Heated O2 sensor malfuction Bank1, sensor2 just wondering which one so i can replace and help given is very appreaciative.
Rizzo
09-09-2010, 03:40 AM
Bank 1 has cylinder 1 in it, That would make it passenger side.
Firewall
4-8
3-7
2-6
1-5
Radiator
Sensor 1 is closest to the manifold,Sensor 2 is after both sets of cats.
