Installing tilt on a non-tilt column
    I want to take the tilt function from the blue Vics column and put it in GO. Can I do that without swapping, or dropping the column?
    Save a seal, club a liberal.
    Hm. given that I've never pulled one apart I'd say I have no idea but I will say its probably going to be easier to swap columns than to install the tilt mechanism. They really aren't all that bad to remove from what I understand. Not sure how the tilt mech works tho or if it would even be possible to retrofit it onto a solid column.
      i'm not 100% sure but i think you have to swap the entire column
        You gotta swap the whole thing mang
          Fuck that,lol. Thanks guys!
            I find I usually set my tilt columns to the same location a non-tilt column would put the wheel so personally I have no particular preference one way or the other. Tho its one more shinly thing sticking out of the column to confuse people with.
