Heater hose workaround...
    Finally got a big portion of the re-installation done on the Merc's drawn-out intake gasket project. And of course, after I torqued down all the bolts I realized that I'd put the stud ones in the wrong place. Now I'm left with no place to mount the damned black steel tube that runs the coolant from the water pump to the heater core. Any way to replace this with just a piece of rubber hose? I'd still keep the part that tee's off to go to the EGR or whatever, but otherwise it'd be replaced with all hose.
    Will my method work? I'm not crazy about re-torquing the whole manifold. PLus, that damn steel thing is probably another source of rust in the cooling system.
    Take some pics.
      hmm
      just leave it "flopping" ther, it won't hurt anything there is enough shit around it to keep it pretty stable, no need to swap it but yes you can just run hose.
      SuperFord Profile
      Support safe sigs
      -sigs should not exceed 600 pixels wide
      -sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
      -Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
      -Total sig size should not exceed 60k
      Remember, only you can prevent sig abuse....
        just swap the two bolts and retorque them......it will be fine
          I also forgot, I blocked off the hose that goes to the EGR on my CFI.
          I have no problems, and no coolant leak!
