View Full Version : Mystery oil loss
85MercPark
01-27-2006, 08:15 AM
My brothers 90s crown vic uses alot of oil. Not leaking and not really burning it. Tried PVC and hoses. About a quart in two weeks. Any ideas?
p71towny
01-27-2006, 10:19 AM
No leaks???? Pop the breather cap off the valve cover and see if a lot of smoky oil comes out from blowby like a mofo.
85MercPark
01-27-2006, 10:21 AM
Nothing that could account for the volume lost.
What does it mean if this is the case? Bad rings?
p71towny
01-27-2006, 10:24 AM
Yup, you can drive it like that but it fouls the plugs easy and will plug the cats after a while.
85MercPark
01-27-2006, 10:26 AM
He hasn't said anything about the plugs fouling, will have to ask him
Johnnyiroc
01-27-2006, 06:16 PM
rear seal? running onto torque converter, but somewhat held up by the converter hole plug, so it just slowly drips out? BTW a 90-91 CV is for the 5.0/5.8 boys. This thread may be better served there depending what year he has.
Lincolnmania
01-27-2006, 06:26 PM
if it'snot leaking out onto the ground,replace the pcv screen.........might be clogged.........or the engine was overheated at one time and the oil control rings on the pistons are toast.........my towncar burned a qt every 400 miles like clockwork
scott
93 Marquis
01-27-2006, 07:52 PM
If it's a 4.6 car, then the problem is valve seals. '91-'95 4.6 heads had a poor design that will cause oil usage over time. The amount of usage varies, but it will be seen in the form of blue smoke out of the tailpipe when the car takes off from a stop, or idles for long periods.
Ray
85MercPark
01-27-2006, 09:44 PM
It is a 4.6, It's a 90s CV, not sure of the exact year.
85MercPark
01-27-2006, 09:50 PM
Did that
scott
exactly, that could be it.
85MercPark
01-27-2006, 09:52 PM
Ray
Or this, have to let him know to check that, those simple on the 4.6's?
BigTomZ
01-27-2006, 10:22 PM
I second the valve seals. 92-95 model years have this problem. Those early (or pre-NPI) 4.6's are notorious for it. Not unlike Chevy's 305 from what I hear.
The valve seals are not a problem on 96+ 4.6's though, Ford used better valve seal material after that.
85MercPark
01-28-2006, 08:21 AM
Thanks I will forward him your advise
:worship:
93 Marquis
01-28-2006, 12:01 PM
On the difficulty scale I'd rate doing your own valve seals at a 8+. Getting the passenger side valve cover off alone is a battle.
Having it done at a shop will cost $600 & up, provided they want to touch it. As BigTomZ said, Ford addressed the problem in the '96-up heads. At the labor cost of the job you could pick up a newer low mileage 4.6 and replace it.
85MercPark
01-28-2006, 08:17 PM
knowing my brother, he will drive it as is forever!
Thanks All
BigTomZ
01-28-2006, 10:37 PM
Yeah actually it would probably be better for him to get another 4.6. He could get a good low mileage PI 4.6 for a nice price if he looks around.
The PI motor would also make more power :headbang:
