the widest tire on the front of a merc? [1986 GMQ]
    hi i was wondering what the widest tire i can run on an 8inch rim for the front of my merc? also whats the widest that will fit the rear of the merc? thanks guys!
    Nick
    I run a 245 wide tire up front on an 8.5" rim with no rubbing and a 275 out back with no rubbing.
    2000 GM LS w/HPP
    K&N FIPK
    Dual Flowmaster 50-series SUV mufflers
    3 & 1/2" rolled, angle cut, polished stainless steel tips
    70mm throttle body from a 5.4L Econoline
    2003 Leather seats with rear cupholder
    2003 Steering wheel w/redundant radio controls
    ADR Spartan triple chrome rims size 19x8.5"
    Falken FK-452 245/40/19 tires
      i run a 255/50/16 on a 7inch rim, so you can prob throw some 295's out there if you really wanted to
      1999 CVPI
      Old Rides
      1988 Ford Mustang GT (trickflow stage 1)
      1989 Mercury Grand Marquis LS (5.SLO)
      1989 Ford Thunderbird SC (3.8 Supacharged)
        I have 325s on the back of mine, they stick out and rub, but my wheels does not have enough backspace. Im going to see if i can run the current 15x10 upfront with like a 285 or so and then get another pair of 15X10 for the rear but with 5" of backspacing. That should allow the 325s to fit under the fender and not rub.
          245's on mine with no problems. There is another guy running IIRC 18x9's with some fairly large tires.
            What year Panther do you drive/own? What wheel size do you have on the car currently?
            '90 Mercury Grand Marquis GS
            5.4L swap coming soon.
              its an 86 grand marquis, the rims i'm getting put on are 16X8 5 inch backspacing (i have 1 inch spacers on the way to take care of the backspacing problem)
              Nick
