Sealant For Coolant Hose
    Ya I know the title sounds stupid but here is my issue. I replaced my lower coolant hose last week. I got it from advance auto parts. It is perfect except it weeps at the T-connector as seen in the picture provided below.
    It is like clamped on there but the clamps are not removeable. Everything I clamped to the fittings is tight and not leaking at all, just the part that the factory made. I paid $59 for this thing and it does this. I can't really return it cause the I had to cut it up cause I have a oil cooler. So my question is what should I use to seal it up at that seam? Use some blue RTV sealant or what?
    Thanks,
    Zack
    If you can whack the factory clamps off there, do that and put a decent clamp on it. RTV on the outside of the hose won't do anything but make a mess.
      I wouldn't use any sealant just try to find some wide hoseclamps. Or some like these that dont damage the hose as it tightens up
      http://www.idealclamp.com/brochure.c...cation_id=2500
      MY 02 GM
      jdmotorsports.org
      04/05 ASC Championship car
      2nd ASC Team car
