--Park is fine.
--To get reverse, you have to put it in nuetral, then back over to reverse.
--OD is fine, but a bit loose.
--Drive is fine, but it is also a bit loose.
--First cannot be found. The shifter will not grab it.
Could this be a shifter cable issue? The trans works good and was recently serviced. All info is appreciated.
