PDA
View Full Version : Engine swap
Roach III
02-06-2006, 12:35 PM
Will the 5.4 fit into a 94 LTC? Or am I stuck with a 5.0 stroker? Just thinking ahead a little. Looking at buying a nice 94.
Paul_
02-06-2006, 01:08 PM
You'd probably have to add a cowl to your hood. IIRC, the 5.4s have a taller upper intake than the 4.6 that would currently be in there. If you want to retain the stock appearance somewhat, I'd go with a 347. There's a guy on CVN who put a 289 into a 92 Crown Vic, so a 347 wouldn't be too hard to do.
DuceAnAHalf
02-06-2006, 04:47 PM
For the $15,000 that the 5.0L cammer costs you could swap in a blown lightning motor and still make it out cheaper.
Freshmeat
02-06-2006, 04:50 PM
x2
Roach III
02-06-2006, 05:37 PM
I believe that DSS racing has a 5.0 stroker long block for like $5199.
93 Marquis
02-06-2006, 05:59 PM
I "think" the 5.4 will fit, but it's going to require modifications. The 5.4 is wider than the 4.6. Your going to have issues with the heater box on the passenger side of engine bay, and the brake booster on the driver's side. Then there's the wiper box that hangs thisclose to the rear of the motor. Also, as stated, the intake is considerably taller than the car model.
So it really depends on how much work your willing to do to make it work.
I say grab a Lightning motor! What's cooler then a blower sticking up through a hole in the hood? :D
Ray
Roach III
02-06-2006, 08:38 PM
Guess the 5.4 is out. Dunno if I'm buying the 94 now. Seems they want $6100 for it. the avg retail in the NADA is like $4425. I will look around some more. I really want a mod motor car to compliment my pushrod TC.
Your responses have been informative. Thankyou.
Lincolnmania
02-06-2006, 10:59 PM
too much for a 90's towncar.........now a 98 for that price would be a steal!......hizhonor bought his creampuff 92 tc for under 2 grand
mrltd
02-07-2006, 12:05 AM
lotta money for a 94. I've looked at a 99 for 6500 with 99K, and will be looking at a 98 with 17.5K for 7500...
93 Marquis
02-07-2006, 09:23 AM
There's a local lot with a white '92 TC that's asking $4995. It looks nice, but that price is NUTS for a '92. I might stop and look at it, just to see if it's a bastard block car...lol.
Hell, I'd sell my Marquis if someone offered me that much! LOL
Chevyguy
02-07-2006, 11:05 AM
lol $6100 for a 94, even $4400 is too high
keep looking, muuuuch bettter bargins out thar
evillally
02-07-2006, 11:32 PM
Dude, build a 351W to 408 and add AFR heads with a good intake. You'll be happy squeezing big block power from that SBF and your wallet will be even happier... :evil:
BigTomZ
02-08-2006, 03:59 AM
Just the stroker kit and AFR heads will cost 2400. You'd want a good cam too. Then of course you'd have to put out some cash to find a serviceable 351. Not to mention that you'd need a transmission to run a 351 in a 94.
You'd be better off getting a PI 4.6 in good condition.
BigTomZ
02-08-2006, 04:04 AM
Personally if I wanted to make power, I'd get a nice PI 4.6 and go with a Kenne-Bell blower. Nothing like beating up on some big blocks, while still having a motor civilized enough for a daily driver.
Freshmeat
02-08-2006, 09:44 AM
It's a toss-up. The 351-408 would be REALLY cool in that ride, but at the same time, it WOULD be a lot of converting taking place. Trust me- it's not fun swapping engine and transmission and wiring stuff all at the same time.
You're about breaking even, because the time you'd save going with a PI 4.6, you'd be spending on money. You have twice (or four times) the cams, depending on which motor, not to mention those parts simply aren't cheap. I'd say order a 5.0 stroker kit from DSS or the like and get the most out of a NA PI 4.6 within reason.
Or you could swap your heads and intakes. I believe the short blocks are the same between non-PI and PI motors. That'd be a lot easier than even pulling the 4.6 to replace it.
Steve83
02-09-2006, 12:34 AM
Where there's a will & a wallet, there's a way. Check out Quint's '78 Bronco w/5.4L (http://home.comcast.net/%7Eqcrispin/bronco/index.htm). He's sicker than I am.
p71towny
02-09-2006, 07:31 PM
Just buy a clean 90 town car, they came with a 302. Then I'd swap on the newer style dog house, tail lamps and doors. It'd be pimp shit.
BigTomZ
02-10-2006, 12:20 AM
Many years ago when the 4.6 was new, this was correct. It is not nowadays.
