PICTURES OF THE 92/97 TO 98 BRAKE CONVERSION
    Ok I have read in many forums and threads about the famous swap,conversion,compatibility of the 98 brakes sistem to a 92/97 Panthers but I have not see any pictues of 92/97 with that modification done in any of the Panther sites I want to do that brake conversion for more brake power in fact I went to Western auto and request a quote for all the parts needed for the conversion. Now if any of the members here can post some pics of a 92/97 CV with that conversion done I will be granted, Thanks for your time to read !MANGS!
    ATT, SNIPER 308. IMPORT COMPACT CARS---->:fucker:<----PANTHER CARS
    MERC75-INTERCEPTOR, BORN IN 2003,DIED IN SEP/21/2010 AT 9:55AM AT THE SORT AHE OF 8 YEARS PROTECTING HIS OWNER TO DIE
    ¿ Anyone can share some pictures of that mod done to a pre '98 ? if a CV better.
    ATT, SNIPER 308. :worship: !! Ohh all mighty SNIPER !!
      if you got time, somewhere in www.grandmarq.net/lincolnmania
        actually there are two styles between 92-97.............theres the 92-early 95 brakes, and mid 95-97 brakes.........sniper we have confirmed that the 95-97 hub bearings will not work with 98-02 front brakes........the caliper bridge hits the rotor with the 95-97 hub bearing......it's just a tad short.........to upgrade your car to 98-02 braakes,you need 98-02 rotors, hub bearings, calipers and hoses..........your spindles are the same as the 98-02 as long as it's a mid 95-97 car
        scott
          Lincolnmania I was checking your picture archive but is too extensive.
          ¿ Do you have pics of the 98 brake swap done ?
          ATT, SNIPER 308. :cops:
            LINCOLNMANIA ¿Can you get me pics of the brake conversion done?
            ATT, SNIPER 308.:cops:
              see if these pictures help any.
              pictures in there of front and rear brake conversions.
                God bless you 88GRANDMARQ MANG you help more than I thought dude, Now hands to work.
                ATT, SNIPER 308. "WELCOME TO THE REAL WORLD" The matrix #1
                  I assume you are doing this swap on your '97 car?
                  96-97 cars already had better brakes then the 92-95 cars, all you need for a conversion is 98-02 hub/bearing, rotors, calipers and pads. the rest of the hardware is the same.
                  Ronman documented the same swap on his 97 GM. I will have ask him where the pictures are.
                    Here is the directory to Ron's brake swap on his 96 GM
                      Hello 88GRANDMARQ MANG you assuming right that mods are for my 97 Crownvic LX(check the sig) so with this info in hand it is sufficient to start the project and I will start from today thanks to all your prompt help I will post pics of every step on this proyect.
                      ATT, SNIPER 308. "YOU CALL THIS...COFFEE" Godzilla.
