Brake line swap? [1991 LTD CV]
    About a year and a half ago, I had the drivers side rear brake line done on the blue Vic. This is the same line that blew on the '91. Can I just swap em? I ask because I don't have the $$ to replace the line.
    Save a seal, club a liberal.
    Should be...
      If its just standard piecemeal replacement line, no reason not to be able to use it. Just be careful taking it out and you should be OK.
        yeah - hopefully they are the same size fittings, wont hurt to try.
        The shape of the line should match no prob.
          replacing steel lines isnt that hard........need a double flaring tool and a tubing cutter..........brake line is cheap........will give brake line install lesson if i have to at scottfest
          scott
