I have a 92 CV Lx and I was wondering if theres a way to unlock the motor? It's locked at 170km.
Engine locked!!!
Marvel mystery oil in the cylinders.1989 Grand Marquis LS
You can't turn the crank at all??? If so your fucked. Did you overheat it, run it without oil, what?? Although in extreme cases, and Ive done it with a small engine, you can pour diesel down in the cylinders and let it soak and it might break free but I doubt it. It will run for a little longer but you still will need a new engine.Chris - A 20th Century Man \m/ ^.^ \m/
I've also heard of filling the crankcase with kero or diesel or something similar and getting it to break loose with a bigass breaker bar. What happened to cause it to lock up? Usually if it locks its pretty much toast.86 Lincoln Town Car (Galactica).
Originally posted by JohnnyirocRemove all 8 plugs and try it, disconnect your coils first. maybe you got a coolant leak and hydro locked it?"Ad eundum quo nemo ante iit"
I dont think dennis can burn a chip for your 92, your best and only bet would be to find a police ecu, and IT HAS TO BE FROM A 92 from what I understand, you cant swap years. It will give you a little better performance and will not be speed limited. Then you can do other mods.Chris - A 20th Century Man \m/ ^.^ \m/
