im an idiot
    im an idiot
    last year i was under my hood solderin all the wires that had butt connectors connecting them. At the time i saw a harness commin out of the distributor with only 1 wire goingin to it. i thought it looked stupid so i cut it out and soldered the wires together. now i know i needed that harness to disconnect the timming advance. so now i can't properly time it and all the wires look the same. can anyone help me out here?
    Just look for wires near the plug for the TFI module on the distributor that have been soldered together
      :owned: :p
      '95 Ford Bronco XL -
      sigpic :rebel:
        What was the electronic advance at idle, 10* on top of the regular one? Then just go for 20*BTDC, to make your life easier there actually is such a mark on the harmonic balancer
          if you need me to, ill break out the EVTM...
            Before i ever bought the car in 1997 it must have had the TFI module harness replaced cuz all the wirws going to it were butt connected together. so they are all soldered to gether know and all look the same. also i tryed setting it at 20*BTDC but withe the ing advance connected it keeps changing so i cant accurately set it. right now its set at 23*@ 2300 rpm. but i'm not sure if it is timed properly
              well, when you convert to carb, you wont have to worry about a spout connector
                nuff said!!!!
