Where can I get replacement T50 seatbelt bolts?
    I'm missing one of the seatbelt bolts in back, and right now I can see the ground,lol. I don't have access to an impact tool, so removing the bolt from one of the Vics in the yard is a no go. It's a T50 bolt. I already broke 3 T50 bits and two ratchets trying to remove the bolts from the '90. :pissed:
    Save a seal, club a liberal.
    Damn dude, those are easy to remove here. The rear seat belts is a diff story.
    Since these are accesible under the car, try some PB blaster on 'em or somthin' maybe?
    '95 Ford Bronco XL -
    sigpic :rebel:
      I'm just debating whether or not I should just wait to get a replacement belt, or not. Where the bolt is missing on the bottom of the back seat is where two buckles should be. I'll try again tomorrow on the '84. Maybe I'll have better luck with that one,lol.
        Wow I'm a dumbass. I read the post and didn't even notice you were talking about the back ones till now. Those are a ROYAL BITCH. How are you seeing daylight? I looked and looked and they don't come thru the floor. Maybe a '90-'91 thang?
        Anyway, you can keep trying if you want. I eventually cut the bracket on the seat back to get it out, on my Vic. Scott tried everything he could as did I, breaking 2 or 3 bits.
        sigpic :rebel:
          shoot some penetrating oil on it from underneath and let it sit. Might not be a bad idea to smack the T50 in there a bit just to jar loose the rust.
            can you get the other one out of GO? I bet you could match up something from Lowes.
